coq-club - Re: [Coq-Club] Ltac unit type
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ltac unit type
  • Date: Thu, 29 Sep 2016 11:09:45 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f177.google.com
  • Ironport-phdr: 9a23:3cpNwRM/oeYdAM/We7Ml6mtUPXoX/o7sNwtQ0KIMzox0KP/4rarrMEGX3/hxlliBBdydsKMezbOH+PC6EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuS9SU1pX8h7r60qaQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vkm7otLVbjwV6U+V71RSjo8YE4v48i+lx7FRBeP731UdmgXjBdOH0CR7hb8X5T8tib3nuV40Siee8bxSOZnCnyZ8653RUqw2288PDkj/TSPhw==
The one use I've found for () is as a dummy arg for a thunk, used to prevent early evaluation of certain overly-greedy Ltac forms, mostly matches:
Goal True.
let f := match goal with _ => idtac "goodbye" end in
idtac "hello"; f. (*prints "goodbye" then "hello"*)
Abort.
Goal True.
let f _ := match goal with _ => idtac "goodbye" end in
idtac "hello"; f (). (*prints "hello" then "goodbye"*)
Abort.
Obviously, anything will work in place of that () - but by using (), one signals what one is doing more clearly, precisely because there is no other use for ().
Also note that, if PMP gets his way in Ltac2, thunks will be required for such cases.
-- Jonathan
On 09/29/2016 04:22 AM, Kyle Stemen wrote:
In the reference manual, () is listed in the ltac syntax. The manual does
not say what it does. The error message from running the following hints
that it has type unit.
Goal False.
Fail let x:=() in revert x.
Abort.
The manual says, "the evaluation yields either a term, an integer or a
tactic," and I don't see how the unit type fits in that list. Of course the
manual doesn't mention the type of context patterns or intro patterns
either.
What is an ltac unit used for? I can't find any built in tactics that
accept it as a parameter.
Ltac true := constr:(true).
Ltac false := constr:(false).
(* Does not work if test_expr fails with a level greater than 0 *)
Ltac would_succeed test_expr :=
match goal with
| _ =>
match goal with
| _ => test_expr; gfail 1
| _ => false
end
| _ => true
end.
(* Takes constr or uconstr *)
Local Tactic Notation "take_term" constr(x) := idtac.
Local Tactic Notation "take_int" int_or_var(x) := idtac.
Local Tactic Notation "take_intropattern" simple_intropattern(x) := idtac.
(* Does not work if test_expr has gfail in it *)
Ltac is_tactic test_expr := would_succeed ltac:(admit; test_expr).
Ltac is_term test_expr := would_succeed ltac:(take_term test_expr).
Ltac is_int test_expr := would_succeed ltac:(take_int test_expr).
Ltac is_intropattern test_expr := would_succeed ltac:(take_intropattern
test_expr).
Ltac is_context test_expr := would_succeed ltac:(first [
let T:=fresh "T" in evar (T:Type); let x:=context test_expr [ T ] in
idtac |
let T:=fresh "T" with a:=fresh "a" in evar (T:Type); evar (a:T); let
x:=context test_expr [ a ] in idtac
Goal nat * nat.
let x:=f_equal in let b:=is_tactic x in
match b with
| true => idtac
end.
let x:=() in let b:=is_tactic x in
match b with
| false => idtac
end.
let x:=constr:(0) in let b:=is_term x in
match b with
| true => idtac
end.
let x:=() in let b:=is_term x in
match b with
| false => idtac
end.
let x:=0 in let b:=is_int x in
match b with
| true => idtac
end.
let x:=() in let b:=is_int x in
match b with
| false => idtac
end.
let x:=fresh "v" in let b:=is_intropattern x in
match b with
| true => idtac
end.
let x:=() in let b:=is_intropattern x in
match b with
| false => idtac
end.
match goal with
| |- context c [ _ ] =>
let b:=is_context c in
match b with
| true => idtac
end
end.
let x:=() in let b:=is_context x in
match b with
| false => idtac
end.
Abort.
The only use I can think of for it is in a function that takes a variable
number of arguments, to terminate the list of arguments.
Ltac is_terminator expr :=
let a:=is_tactic expr in
let b:=is_term expr in
let c:=is_int expr in
let d:=is_intropattern expr in
let e:=is_context expr in
match true with
| a => false
| b => false
| c => false
| d => false
| e => false
| _ => true
end.
Ltac count_args :=
let rec count total arg :=
match (is_terminator arg) with
| true => total
| false => count (S total)
end in
count 0.
Goal False.
let x:=count_args 1 2 3 f_equal () in idtac x.
Abort.
