- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] General reflection-based rewriting
- Date: Mon, 10 Oct 2016 15:22:02 +0200
Hi. Just for the record, let me mention the related work of Nguyen Quang Huy some years ago... - Compact normalisation trace via lazy rewriting 10.1016/S1571-0661(04)00269-5 10.1016/S1571-0661(04)00295-6 - Rewriting Calculus and Automation of Proofs in Proof Assistants http://protheo.loria.fr/users/nguyenqh/Thesis/thesis.pdf - An ELAN-based tactic for AC rewriting in Coq is available here - A Coq/ELAN interface for equational reasoning in Coq See http://protheo.loria.fr/users/nguyenqh/ . Le 08/10/2016 à 16:45, Stefan Ciobaca a
écrit :
Nice! I would be very much interested in such a system.
I am aware of the following PhD thesis http://homepage.cs.uri.edu/faculty/hamel/pubs/theses/phd-thesis-kaplan.pdf
in which (part) of rewriting logic is formalized in Coq. I'm
not sure to what degree you can reuse this, but it might be a
good starting point.
Best, Stefan On Sat, Oct 8, 2016 at 4:56 PM, Jannis
Limperg <jannis AT limperg.de>
wrote:
Dear Coq-Club, I'm currently prototyping a library for general reflection-based rewriting. The goal is to allow users to relatively easily specify rewriting systems for arbitrary theories and use them to normalise/simplify terms. To that end, I currently plan to proceed as follows: - Define a generic representation of terms, probably similar to that of the CoLoR library. - Have users provide a signature describing which interpreted symbols their terms contain, and an interpretation function from the representation to actual terms. - Define a generic reflection tactic that, given a signature, reflects the user's terms into the representation. (Not sure how much the user has to help here.) - Define transformations of representation terms for common properties (associativity, symmetry, etc. pp.) and prove them correct (given a proof that the user's terms actually have those properties). Allow users to define transformations specific to their theories. - Tie different transformations together with a fixpoint construction. [1] One may view this as a generalisation of the ring/field tactics (though I don't plan to reimplement those, at least not initially). Compared to autorewrite, my scheme has the advantage of being able to exploit orders on representation terms, which comes in handy when normalising symmetric operations. Now finally the question: Are you aware of any similar systems (in Coq or elsewhere), or do you have any general advice/gotchas that I should be aware of? I'd like to make as sure as possible that such a library has at least a chance of being useful before spending a lot of time on it. Thanks, Jannis [1] I plan to have the user be responsible for the termination of their rewriting system. Everything else imho just leads to massive complexity. |
- [Coq-Club] General reflection-based rewriting, Jannis Limperg, 10/08/2016
- Re: [Coq-Club] General reflection-based rewriting, Morrisett, 10/08/2016
- Re: [Coq-Club] General reflection-based rewriting, Stefan Ciobaca, 10/08/2016
- Re: [Coq-Club] General reflection-based rewriting, Frédéric Blanqui, 10/10/2016
- Re: [Coq-Club] General reflection-based rewriting, Gregory Malecha, 10/09/2016
- Re: [Coq-Club] MirrorCore [was: General reflection-based rewriting], Jannis Limperg, 10/30/2016
