- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "Official" Source for native-coq
- Date: Wed, 12 Oct 2016 08:48:20 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 16.mo5.mail-out.ovh.net
- Ironport-phdr: 9a23:hCvq2BGS4QRzFeT8ffpUbZ1GYnF86YWxBRYc798ds5kLTJ75pcWwAkXT6L1XgUPTWs2DsrQf2rCQ7/mrCDBIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD1YLrjqvjp9X6WEZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEzmRBuO43ZUfuQQEgEAVw3M7RXSW57hsy73uud71TLcM9egHuN8Yiir86o+EEygsywALTNsqGw=
Hello,
I'm working on it, but I'm a bit slow due to the work on 8.6 beta 1 I'm
doing at the same time.
Sorry about that.
Maxime.
On 10/12/16 00:26, Christoph-Simon Senjak wrote:
> Hi.
> Any progress yet?
> Best Regards,
> On 22.09.2016 17:51, Christoph-Simon Senjak wrote:
>> Hello.
>> On 21.09.2016 12:54, Maxime Dénès wrote:
>>> Hello,
>>> I'm sorry, it is indeed confusing.
>>> The original "native-coq" repository is the one you found on github. It
>>> contains a modified version of Coq with native code compilation and
>>> primitive integers and arrays.
>>> That version of Coq is loosely based on Coq 8.4, so it is indeed quite
>>> outdated. Note that the native code compilation part has been integrated
>>> in Coq, so native-coq is relevant only if you need primitive integers or
>>> arrays.
>> Indeed, I am interested in the diffarray-implementation.
>>> Since other users have asked for it, I'll try to port these integers and
>>> arrays to a more recent version of Coq, and will keep you posted. It
>>> should take a week or so.
>> Thank You
>> CSS
>>> Maxime.
>>> On 09/21/16 12:37, Christoph-Simon Senjak wrote:
>>>> Hello.
>>>> I found several repositories of native-coq, most of them seem to be
>>>> forks. What is the original repository of native-coq? I found [1]
>>>> which
>>>> is by Maxime Dénès who is an author of the paper [2] so this is
>>>> probably
>>>> a good source, but it hasn't been updated since 2015 and it appears to
>>>> be forked from some svn-branch.
>>>> Regards,
>>>> [1]:https://github.com/maximedenes/native-coq
>>>> [2]:https://coq.inria.fr/files/GTCoq2013_denes.pdf
- Re: [Coq-Club] "Official" Source for native-coq, Christoph-Simon Senjak, 10/12/2016
- Re: [Coq-Club] "Official" Source for native-coq, Maxime Dénès, 10/12/2016
