coq-club - [Coq-Club] pattern match not reducing
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] pattern match not reducing
  • Date: Wed, 26 Oct 2016 13:40:21 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hendrik AT askra.de; spf=None smtp.mailfrom=hendrik AT askra.de; spf=None smtp.helo=postmaster AT mx4.sysproserver.de
  • Ironport-phdr: 9a23:+23lDhb/T9KSgdxrrLt8wz7/LSx+4OfEezUN459isYplN5qZpc68bnLW6fgltlLVR4KTs6sC0LuM9f6xEjZZqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3p7xibH5ocSbSj4LrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVHSODxe7kyZb1eFjUvdW4vt+PxshyWbQaJ6mEdUS0qnwVTS1zF4Rf2RJbymiLhtfB0niWXa56lBYsoUCivuv84ACTjjz0KYmY0
Hi everybody,
I have a problem with updating a dependently typed function from
8.4 to 8.5 (see the source below). In 8.4, coq accepts the
definition of merge_partial_tuple with {struct pt1} and the proof
of the little lemma is very simple.
In 8.5, {struct pt1} is rejected, coq does not see anymore that
pt1_tail' and pt1_tail are identical.
First question: Is this an intended change?
However, in 8.5 the definition is accepted with {struct pt2}. For
this, I would say, coq has to infer that pt2 and pt2' are
identical, which does not seem to be a problem.
I don't care too much about the decreasing argument. My problem
is that with {struct pt2} the term
merge_partial_tuple (counted_nil _) something
is not convertible to (counted_nil _). (This behavior is the same
in 8.4 and 8.5.) I would be grateful if somebody could tell me
why coq does not use the obvious first case in the pattern match
to reduce the term. Indeed,
change (merge_partial_tuple (counted_nil (option nat)) pt) with
(counted_nil (option nat)).
fails with "Not convertible.", which I really don't understand.
Thanks in advance,
Hendrik
==================== 8.4 version
Section Counted_list.
Variable A : Type.
Inductive counted_list : nat -> Type := (* lists of fixed length *)
| counted_nil : counted_list 0
| counted_cons : forall(n : nat),
A -> counted_list n -> counted_list (S n).
End Counted_list.
Definition partial_tuple(n : nat) : Type := counted_list (option nat) n.
(* this function should do
[Some 0; Some 1; None] [None, Some 2; None] => [Some 0; Some 1; None]
Fixpoint merge_partial_tuple{l : nat}(pt1 pt2 : partial_tuple l)
{struct pt1} : partial_tuple l
match pt1 in counted_list _ l1
return partial_tuple l1 -> partial_tuple l1
with
| counted_nil => fun _ => counted_nil _
| counted_cons pl1 no1 pt1_tail => fun(pt2' : partial_tuple (S pl1)) =>
match pt2' in counted_list _ l2
return match l2 with
| 0 => nat (* impossible case *)
| S pl2 => partial_tuple pl2 -> partial_tuple (S pl2)
end
with
| counted_nil => 0 (* impossible case *)
| counted_cons _ no2 pt2_tail => fun pt1_tail' =>
match no1 with
| Some n1 => counted_cons _ _ (Some n1)
(merge_partial_tuple pt1_tail' pt2_tail)
| None => match no2 with
| Some n2 => counted_cons _ _ (Some n2)
| None => counted_cons _ _ None
end
end
end pt1_tail
end pt2.
Lemma merge_partial_tuple_nil :
forall(pt : partial_tuple 0),
merge_partial_tuple (counted_nil _) pt = (counted_nil _).
Proof.
intros pt.
simpl.
reflexivity.
Qed.
==================== end 8.4 version
======================= 8.5 version of merge_partial_tuple
{struct pt2} : partial_tuple l
with
| counted_nil _ => fun _ => counted_nil _
| counted_cons _ pl1 no1 pt1_tail => fun(pt2' : partial_tuple (S pl1)) =>
end
with
| counted_nil _ => 0 (* impossible case *)
| counted_cons _ _ no2 pt2_tail => fun pt1_tail' =>
match no1 with
end
end
end pt1_tail
end pt2.
======================= end
