- To: Gregory Malecha <gmalecha AT gmail.com>
- Cc: Jason Gross <jgross AT mit.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] list :: nil?
- Date: Wed, 26 Oct 2016 10:51:50 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sherman AT csail.mit.edu; spf=Pass smtp.mailfrom=sherman AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-stata.csail.mit.edu
- Ironport-phdr: 9a23:chSunxEw3kzSWsI2wCn67p1GYnF86YWxBRYc798ds5kLTJ75ps6wAkXT6L1XgUPTWs2DsrQf2rCQ7fGrBzdIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScb6xv663OGq+pDVfx4AxH/kOeszf12KqlD+rMQZhpFzYoM4zhbConIAL+tTzGdlLlKatxn578a0upVk9nIDlegm8ptqXKOyRKQ1V7lRCnxyKGA4/sjiszHIVgKO4j0ZU3lQnxZVVVuWpCrmV4v853Op/tF23zOXaIivFeg5
Hi Gregory,
I've experienced similar issues. In particular, I had issues with `prod`,
where I was occasionally not using it in a fully applied manner, so it in
fact didn't end up being universe-polymorphic, and then I had universe
inconsistencies as a result. In particular, it affected using typeclass-based
rewriting (i.e., CRelationClasses/CMorphisms), because `iffT` is defined
using `prod`. So one non-polymorphic use of `prod` broke behavior of `iffT`,
even though `iffT` has a fully applied use of `prod`.
One option to fix this, which I don't particularly like, is to make sure that
*every* use of `prod` is "fully applied", that is, that it instantiates
arguments to `prod` with universe-polymorphic types.
The other option, which I took, is to just redefine `prod` with universe
polymorphism, and use that instead:
https://github.com/bmsherman/topology/blob/master/src/StdLib.v
The reason why I like this approach is because it makes it easier to reason
about universes. That is, it can make it so definitions have fewer universe
constraints. For any definition using template-polymorphic `prod` (even if it
is fully applied), you'll get universe constraints that look something like
Univ < Coq.Init.Datatypes.19
Univ < Coq.Init.Datatypes.20
where `Coq.Init.Datatypes.[19-20]` are the two universes for the arguments to
the template-polymorphic `prod` definition in the standard library. I think
that these constraints aren't really a worry, because we can just let
`Coq.Init.Datatypes.[19-20]` be arbitrarily big. But I guess that when `prod`
isn't fully applied, you can get lower bounds on these universe levels, too,
which is an issue.
Anyway, I like never having to look at constraints like the one above in the
first place; it makes it easier to figure out what's going on with universes.
So I suggest the seemingly radical option of redefining `prod` (or whatever
datatype it is for you) in a universe-polymorphic manner.
(There's a feature request for more documentation on template polymorphism in
the Coq bug tracker:
https://coq.inria.fr/bugs/show_bug.cgi?id=4860)
Ben
- [Coq-Club] list :: nil?, Gregory Malecha, 10/22/2016
- Re: [Coq-Club] list :: nil?, Jason Gross, 10/22/2016
- Re: [Coq-Club] list :: nil?, Matthieu Sozeau, 10/22/2016
- <Possible follow-up(s)>
- Re: [Coq-Club] list :: nil?, Ben Sherman, 10/26/2016
