coq-club - Re: [Coq-Club] simpl should reduce on constructor?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] simpl should reduce on constructor?
  • Date: Sat, 29 Oct 2016 22:31:34 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gmalecha AT gmail.com; spf=Pass smtp.mailfrom=gmalecha AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f176.google.com
  • Ironport-phdr: 9a23:NU5ZFRLwgryR/tqyhtmcpTZWNBhigK39O0sv0rFitYgUKf3xwZ3uMQTl6Ol3ixeRBMOAuqgC1LSd6vqocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+kQMiN0Y/ujaibwN76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsPU4ssVETK/SfqIiTLUeAi51HXoy4ZjErxTMShGerl4VVmgdkhMAVwfA5RX3VZf4miT/v+t5niKdOJulHvgPRT2+4vIzG1fTgyAdOmth/Q==
Excellent. Thanks.
On Sat, Oct 29, 2016 at 2:46 PM Maxime Dénès <mail AT maximedenes.fr> wrote:
Sorry, my previous message was incomplete. As a workaround, you can do:
Arguments baz {_ _} !pf _ /.
Note the "/".
This bug is known and being fixed in 8.6.
Hope it helps.
Maxime.
On 10/29/16 20:44, Maxime Dénès wrote:
> Hi Greg,
> Arguments baz {_ _} !pf _.
> On 10/29/16 19:46, Gregory Malecha wrote:
>> Hello --
>> I have three functions that look roughly like this:
>> Definition foo {a b : Type} (F : Type -> Type) (pf : a = b) : F a -> F b :=
>>   match pf with
>>   | eq_refl => fun x => x
>>   end.
>> Definition bar {a b : Type} (pf : a = b) : a -> b :=
>>   @foo a b (fun x => x) pf.
>> Definition baz {a b : Type} (pf : a = b) : b -> a :=
>>   @bar b a (eq_sym pf).
>> I am writing the following annotations for simpl.
>> Arguments foo {_ _} _ !pf _.
>> Arguments bar {_ _} !pf _.
>> And I get the following behavior:
>> Eval simpl in @foo nat nat (fun x => x) eq_refl 1. (* = 1 *)
>> Eval simpl in @bar nat nat eq_refl 1. (* = 1 *)
>> Eval simpl in @baz nat nat eq_refl 1. (* = baz eq_refl 1 *)
>> The first two of these are exactly what I expect, but the third seems
>> wrong. If I understand correctly, the documentation says that baz should
>> be reduced if the proof argument is a constructor (which it is:
>> eq_refl). Once that unfolds, eq_sym should reduce since it is applied to
>> a constructor (just to be sure I added an: Arguments eq_sym {_ _ _}
>> !_.), and then bar should reduce and finally foo should reduce.
>> Is there any work-around that does not involve inlining the definition
>> of `foo` inside `baz`?
>> Thanks.
>> - gregory malecha
>>   gmalecha.github.io <http://gmalecha.github.io>
- gregory malecha
  gmalecha.github.io
