coq-club - Re: [Coq-Club] Cumulative inductive types and universe polymorphism
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Cumulative inductive types and universe polymorphism
  • Date: Mon, 7 Nov 2016 09:10:56 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f181.google.com
  • Ironport-phdr: 9a23:hSKj8ROQyTt5DQYbGtYl6mtUPXoX/o7sNwtQ0KIMzox0KPzyrarrMEGX3/hxlliBBdydsKMezbuN+PqwACRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUqabtcm81viz9pvPeE0IwWPlOfIhZCmx+C7Wr4E9hZZoYvI6zQKMqX9VccxXw3lpLBSdhUCvyN23+ctJ+j8YgOog69JNS76yK65+RPpHSi8+Mnwp6dfwnRbGRAqLoHAbVzNFwVJzHwHZ4USiDd/KuSzgu784gXHCMA==
For the record, we found some likely applications for cumulative
inductive types here.
(As Matthieu knows well :-) )
Andrej Bauer, Jason Gross, Peter LeFanu Lumsdaine, Mike Shulman,
Matthieu Sozeau, Bas Spitters,
The HoTT Library: A formalization of homotopy type theory in Coq
https://arxiv.org/abs/1610.04591
On Mon, Nov 7, 2016 at 7:35 AM, Matthieu Sozeau
<mattam AT mattam.org>
wrote:
> Hi David,
> Yes, we're planning to work on it with Amin Timany for 8.7 or the following
> version.
> Do you have a particular application in mind?
> Best,
> -- Matthieu
> On Sun, 6 Nov 2016 at 23:50, David Leduc
> <david.leduc6 AT googlemail.com>
> wrote:
>> Hello,
>> Universe polymorphism does not currently support cumulativity for
>> inductive types [1]. Is there any plan to add this feature in future
>> versions of Coq (8.6 or later)?
>> [1] Amin Timany, Bart Jacobs. First Steps Towards Cumulative Inductive
>> Types in CIC.
>> http://www.cs.kuleuven.be/publicaties/rapporten/cw/CW684.abs.html
