- From: Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Automation with existential goals
- Date: Mon, 14 Nov 2016 11:00:09 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=klaus.ostermann AT uni-tuebingen.de; spf=None smtp.mailfrom=klaus.ostermann AT uni-tuebingen.de; spf=None smtp.helo=postmaster AT mx04.uni-tuebingen.de
- Ironport-phdr: 9a23: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
Hello Pierre, thanks for the suggestion. Putting the "@ex" into the For instance, consider Inductive foo : Set := Goal foo -> exists {n:nat}, baz n. Usually I'd hope to be able to use Klaus Am 14/11/16 um 10:46 schrieb Pierre
Courtieu:
Hi,
I am not sure when exactly you want to trigger the destruct
but you can match goal on ex like below.
Ltac destruct_foo :=
match goal with
| H:foo |- @ex _ (fun n => @eq nat n 7) =>
destruct H
end.
Hint Extern 1 => destruct_foo:foo. (* you can add
same pattern than above @ex... *)
Goal foo -> exists {n:nat}, n=7.
intros.
eauto with foo.
2016-11-14 10:22 GMT+01:00 Klaus
Ostermann <klaus.ostermann AT uni-tuebingen.de>:
When proving a goal with an existential, it matters when eexists is used. For instance, with Inductive foo : Set := | bar : forall n, n = 7 -> foo. the following proof works Goal foo -> exists {n:nat}, n=7. intros. destruct H. eexists. exact(e). Defined. but this one yields a "cannot instantiate ... not in scope" error Goal foo -> exists {n:nat}, n=7. intros. eexists. destruct H. exact(e). It's easy to correct this error in a manual proof, but it is not clear to me how to deal with such goals in (goal-direct) proof automation. In principle, I could automate proofs like that using something like Hint Extern 1 (?n = 7) => match goal with | [ H : foo |- ?n = 7 ] => destruct H end. but the hint won't fire until I used "eexists" first - but I need to use eexists _after_ the "destruct". Is there a way to solve this conundrum? Klaus |
- [Coq-Club] Automation with existential goals, Klaus Ostermann, 11/14/2016
- Re: [Coq-Club] Automation with existential goals, Pierre Courtieu, 11/14/2016
- Re: [Coq-Club] Automation with existential goals, Klaus Ostermann, 11/14/2016
- Re: [Coq-Club] Automation with existential goals, Jonathan Leivent, 11/14/2016
- Re: [Coq-Club] Automation with existential goals, Jonathan Leivent, 11/16/2016
