coq-club - Re: [Coq-Club] opaque -> transparent : workarounds?
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] opaque -> transparent : workarounds?
  • Date: Tue, 15 Nov 2016 13:48:40 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f176.google.com
  • Ironport-phdr: 9a23:cZMdwB/hI2DRCf9uRHKM819IXTAuvvDOBiVQ1KB+2u4cTK2v8tzYMVDF4r011RmSDN6dsqgP0rOM++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9dazJHdvZiN3y3OSv8dWHaAJRwTG5fLlaLROsrAyXuNNA0qV4LaNk4xHJo2BIduce7GVhI17byx/25sar/JNgtS1WsvQtsc9BTarScKExTLgeBzMjZTNmrPb3vAXOGFPcrkAXVX8bx0JF
Hi Maxime,
I often end up with functions that don't compute because they use opaque definitions/lemmas (saved using Qed) at critical places, e.g. discriminees of match, guards of fixpoints.
Also, I vaguely remember instances when Coq's productivity check rejected my proofs because of the opacity of some subcomponents.
I am not the only one with such misfortune of not being able to use (e.g. for proof by computation) what has been paid for (by constructive proofs):
https://sympa.inria.fr/sympa/arc/coq-club/2013-09/msg00033.html
https://sympa.inria.fr/sympa/arc/coq-club/2015-02/msg00075.html
https://sympa.inria.fr/sympa/arc/coq-club/2015-11/msg00173.html
On this list, there have been many discussions about workarounds for specific cases, particularly when the opaque lemmas/definitions are about decidable properties:
https://sympa.inria.fr/sympa/arc/coq-club/2016-04/msg00081.html
Even in those cases, some manual work is needed : one needs to identify the critical opaque parts and redefine them.
I want something that effortlessly always restores canonicity.
Thanks,
On Tue, Nov 15, 2016 at 12:09 PM, Maxime Dénès <mail AT maximedenes.fr> wrote:
Hi Abishek,
Can you share a bit of context about your use case?
Thanks!
Maxime.
On 11/15/16 18:03, Abhishek Anand wrote:
> My understanding is that once a definition is saved with Qed, there is
> no way to make it transparent.
> Is that true?
> If so, has someone written a plugin/tool to take a definition (say of X)
> with possibly opaque parts and recursively transparently duplicate those
> parts to create a new totally transparent definition (say X_t)?
> Perhaps no new Coq plugin is needed -- template-coq
> <https://github.com/gmalecha/template-coq>'s `Quote Recursively` already
> reifies opaque bodies. Also, it has "Make Definition" to reflect back
> encodings of definitions. It seems possible to write Ltac/Gallina
> functions that use template-coq commands to achieve the above-mentioned
> transparentification. Am I overlooking some difficulty?
> Thanks,
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/ <http://www.cs.cornell.edu/~aa755/>
