- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coqc and coqtop differ in what they can prove.
- Date: Sun, 20 Nov 2016 14:42:21 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f178.google.com
- Ironport-phdr: 9a23:MzSVkBGFfRTuVMeFbkdo251GYnF86YWxBRYc798ds5kLTJ76r8WwAkXT6L1XgUPTWs2DsrQf2rGQ6fqrADZdqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2aue3siLv3o8GbI1gQxWn1XbQnJxKv6A7Vq8M+gI14K693xAGajGFPfrF0wmVhOVKamV7Y68au8Zh/u3BSvPQg9MNEXKjScKExTLgeBzMjZTNmrPb3vAXOGFPcrkAXVX8bx0cQDg==
I think you should definitely report this to https://coq.inria.fr/bugs/
If you can, make a small example that reproduces the bug, and attach it to the bug report.
-- Jonathan
On 11/20/2016 02:36 PM, Alexandre Pilkiewicz wrote:
After figuring it out that I can print goals with Print. and fail right
after, I found out the difference.
The tactic
autounfold with autounfold in *.
does less unfolding in coqc. In particular, it does not unfold in coqc (but
does in coqtop) a function defined like this:
Definition Pol_In v (pol: Polyhedron) :=
list_forall (satisfy_constraint v) pol.
I manually unfold it and the proof now passes in both, but it still is
quite weird.
Alex
On Sun, Nov 20, 2016 at 8:09 PM, Alexandre Pilkiewicz <
alexandre.pilkiewicz AT polytechnique.org>
wrote:
All,
I am fixing an old Coq development, and I'm hitting a snag: one file
compiles fine in coqtop but fails with coqc, and I don't understand why,
nor do I know how to debug.
coqc --version and coqtop --version return the same thing.
The Coq Proof Assistant, version 8.5pl3 (November 2016)
compiled on Nov 19 2016 16:24:18 with OCaml 4.03.0
cat MyFile.v | coqtop
works like a charm (so does running it in proof general)
but then coqc MyFile.v fails with
File "./MyFile.v", line 161, characters 2-5:
In nested Ltac calls to "lia" and "xlia", last call failed.
Error: Tactic failure: Cannot find witness.
If I replace lia with omega, it still works with coqtop, still fails with
coqc, so it's not just a lia issue.
Error: Omega can't solve this system
Is this a common thing (maybe they use different environment variables or
something)?
Is there a way to ask coqc to tell me what is the current state of the
goal (-verbose does not help)
Thanks in advance!
Alex
- [Coq-Club] coqc and coqtop differ in what they can prove., Alexandre Pilkiewicz, 11/20/2016
- Re: [Coq-Club] coqc and coqtop differ in what they can prove., Alexandre Pilkiewicz, 11/20/2016
- Re: [Coq-Club] coqc and coqtop differ in what they can prove., Jonathan Leivent, 11/20/2016
