coq-club - Re: [Coq-Club] Unification Bug?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unification Bug?
  • Date: Fri, 2 Dec 2016 17:39:23 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f176.google.com
  • Ironport-phdr: 9a23:0h86dxUtCXVCt28Y2eHJi67Lc6HV8LGtZVwlr6E/grcLSJyIuqrYZROGt8tkgFKBZ4jH8fUM07OQ6PG7HzBcqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1KllLK8tyhLP6l9Fevpbw38gcVCUmRf/68O98bZs9i1Rv7Qq8MsWAvayRLgxUbENVGduCGsy/sC+7RQ=
On 12/02/2016 04:54 PM, Eddy Westbrook wrote:
Thanks for your help, Jonathan.
Is there any way to search a term to find all the evars in it, so I can
skolemize all of them? I would like to do something like this, where R is a
typeclass that only has an instance for non-dependent function types:
Ltac prove_R :=
lazymatch goal with
| |- R (forall x:?A, ?B) => skolemize_all_evars B; apply
R_nondep_fun_instance
end.
Thanks again,
-Eddy
It should be possible to write a tactic that skolemizes every evar-under-binders in a term with respect to just those binders it is under. But, if you want to apply a non-dependent lemma, then you have to clear the dependent vars, not revert them, right?
However, the same tactic mechanism could probably do either, subbing clear for revert...
Part of the trick to doing this is to understand that instantiate can reach evars under binders, while match contexts cannot - hence one can remove top-level evars by something like:
repeat match goal with
|- context[?E] => is_evar E; set E
end.
The next part of the trick is harder, as one has to descend under binders to accumulate the variables that one wants to skolemize remaining evars with respect to, then call instantiate (1:=ltac:(revert V)) for each of those, in the right order. Then when the next evar is skolemized, do the above match again to factor it out of the goal, and repeat...
If a brute-force skolemization (all vars, even if not a binder) is OK, one can just do instantiate (1:=ltac:(revert_all)) instead, where revert_all is:
Ltac revert_all := repeat lazymatch goal with H:_ |- _ => revert H end.
in which case, there is no need to descend under binders.
I've written versions of the brute-force tactic, but not the careful one. I guess I could give it a try....
-- Jonathan
