coq-club - Re: [Coq-Club] Adding strong induction to the standard library
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Adding strong induction to the standard library
  • Date: Mon, 5 Dec 2016 17:41:24 +0100
  • Organization: LORIA
Le 05/12/2016 à 16:48, Tej Chajed a écrit :
> I stand corrected, I didn’t realize strong induction was well-founded
> induction on lt (this is actually the first I’ve seen a reference to
> [well_founded induction lt_wf]).
Indeed you could have proved your strong_induction that way ...
Definition strong_induction := well_founded_induction lt_wf.
Notice you also have recursion principles (to build terms in Set/Type
instead of just prove formulas in Prop)
Check well_founded_induction_type.
and a fixpoint based on well-founded induction
Check Fix.
if you want to define terms with which you need to compute.
> In that case, it would be good to find a place in the documentation to
> mention this, such that searching for “strong induction coq” pulls this up.
A good place to start with is in the documentation of the
Standard Library module Wf.
https://coq.inria.fr/distrib/current/stdlib/Coq.Init.Wf.html
Well founded induction is a really tremendous tool to prove
by induction in Coq. Do not hesitate to define lots of different
induction principles to suit your needs.
Best
Dominique
