coq-club - Re: [Coq-Club] Rewriting in arithmetic expressions wrt Z.le
  • From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewriting in arithmetic expressions wrt Z.le
  • Date: Tue, 6 Dec 2016 19:27:01 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=armael.gueneau AT ens-lyon.fr; spf=Pass smtp.mailfrom=armael.gueneau AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:vgIQjxFF+92cBAwP6GopZZ1GYnF86YWxBRYc798ds5kLTJ76oMWwAkXT6L1XgUPTWs2DsrQf2rGQ7virBDZIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwguu14tjYZxhCrDu7e7J7ahus/ivLscxDqJFnIyU1/TTUI31FcvkekWpyIFuem1Dz+8q28Zd+2ylWoLcl5slGF6vgKfdrBYdEBSgrZjhmrPbgsgPOGFOC
Thanks for the tip Théo.
I tried it, and it worked locally; however, if I define such a hint in my whole proof script, it breaks unrelated rewrites, by (I assume) shelving things that would previously just be skipped.
— Armaël
On 06/12/2016 18:47, Théo Zimmermann wrote:
Hi Armaël,
There is a way to instrument type class resolution in "forward mode" :
Hint Extern 100 (0 <= _) => shelve : typeclass_instances.
Goal forall a b c d, a <= b -> 0 <= c -> c * b <= c * d -> c * a <= c * d.
  intros ? ? ? ? a_le_b O_le_c cb_le_cd.
  unshelve rewrite a_le_b.
______________________________________(1/2)
c * b <= c * d
______________________________________(2/2)
0 <= c
  all:assumption.
Qed.
The external hint shelves the sub-goal instead of solving it. Then the unshelve tactical set it back for the user to solve.
I tested the modified code with both 8.5 and the current 8.6 branch.
I wonder how well this trick is known by heavy users of type classes.
Théo
Le mar. 6 déc. 2016 à 18:03, Armaël Guéneau <armael.gueneau AT ens-lyon.fr> a écrit :
Hi list,
I'm trying to setup definitions to be able to rewrite wrt Z.le in
arithmetic expressions (which live in Z).
For example, I can define the following instance to be able to rewrite
under Z.add:
     Program Instance proper_Zplus: Proper (Z.le ++> Z.le ++> Z.le) Z.add.
     Next Obligation. do 6 intro. omega. Qed.
This one works well, as illustrated in the following example:
     Goal (forall a b c d, a <= b -> c + b <= c + d -> c + a <= c + d).
       intros ? ? ? ? a_le_b cb_le_cd.
       rewrite a_le_b.
       assumption.
     Qed.
However, I have issues trying to do the same with multiplication.
"Proper (Z.le ++> Z.le ++> Z.le) Z.mul" is not true in general, so I'd like to add a side condition asserting that
the constant under which I rewrite
is non-negative.
This gives me this first instance, which allows to rewrite on the right
of Z.mul:
     Program Instance proper_Zmult_right:
       forall x, 0 <= x ->
       Proper (Z.le ++> Z.le) (Z.mul x).      Next Obligation. do 3 intro. nia. Qed.
This instance doesn't work as is; a previous thread (https://sympa.inria.fr/sympa/arc/coq-club/2013-03/msg00101.html) seems to suggest that a way to make it work is by adding a hint
Hint Extern 100 (0 <= _) => assumption : typeclass_instances.
and then asserting the side-condition before rewriting with this instance.
Inserting this hint feels a bit hackish, and having to assert the side
condition beforehand is not super convenient.
Moreover, I can't manage to define an similar instance to rewrite on the
left of Z.mul. The following doesn't work:
     Program Instance proper_Zmult_left:
       forall y, 0 <= y ->
       Proper (Z.le ++> Z.le) (fun x => Z.mul x y).      Next Obligation. do 3 intro. nia. Qed.
(attached is a minimal Coq script with the definitions & test cases)
Is there a better way of doing this setup so that rewriting under Z.mul
works?
More generally, how do people prove and handle inequalities between
arithmetic expressions?
— Armaël
