coq-club - Re: [Coq-Club] Module Include leads to duplicate type class instances
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Module Include leads to duplicate type class instances
  • Date: Tue, 13 Dec 2016 18:21:35 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp2.science.ru.nl
  • Ironport-phdr: 9a23:4YgwGxDN/l/cMMKbm8d0UyQJP3N1i/DPJgcQr6AfoPdwSP77p8bcNUDSrc9gkEXOFd2CrakV0KyI7+u8AyRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrj71Jvskrjus92OO0QbzAa6NLh1NVC9qRjbnsgQm4prbKgrmTXTpX4dQeNcz25yORqwhRv27Mqq59Y39i1Rv/Mn+MpBSrnhV74/R7ZVFiglKW0/7sDxrl/FSV3ctTMnTmwKn08QUED+5xbgU8Ks6iY=
Thanks for the suggestion, that solves our problem!
On 12/13/2016 05:33 PM, Jason Gross wrote:
I would call this a misfeature or a known design issue. There is a
similar issue with module functor application.
If you just want namespacing, try this module structure instead:
Module Export foo1.
Module bar. ... End bar.
End foo1.
Module Export foo2.
End foo2.
If you also want [Import bar] to do the right thing, you can create
another module [bar] which [Export]s all of the inner modules [bar].
On Tue, Dec 13, 2016, 3:22 AM Robbert Krebbers
<mailto:mailinglists AT robbertkrebbers.nl>>
wrote:
Hi Coq-club,
We noticed that Including a module leads to all type class instances
being redeclared. In the example below this will make type class search
backtrack on foo.c_and and bar.c_and for each subterm, and thereby
turning a search that takes linear time into a search that takes
exponential time.
Is it a feature or a bug that type class instances are being redeclared
when a module is included?
Does someone know a workaround for the problem? Some solutions that we
came up with:
- We could just not declare instances in the module `foo`, but
instead use `Existing Instances` in `bar`. [In our actual code we have
about 100 such instances in `foo`, so this does not really scale.]
- We could `Export` foo in bar instead of including it, but that makes
it impossible to refer to lemmas lem in foo as bar.lem. [In our actual
code, we are using modules this way to include several modules `foo1`,
`foo2` and `foo3` into one module `bar` so as to be able to refer to
lemmas in `foo1`, `foo2` and `foo3` through one common namespace `bar`).
Best,
Robbert
* Thanks to JH Jourdan for finding this problem in our actual code:
https://gitlab.mpi-sws.org/FP/iris-coq/blob/master/theories/base_logic/base_logic.v
Class C (P : Prop) := { }.
Module foo.
Instance c_true : C True.
Instance c_and P Q : C P -> C Q -> C (P /\ Q).
End foo.
Module bar.
Include foo.
End bar.
Goal C (True /\ True /\ True /\ True /\ True /\ True /\ True /\ True /\
True /\ True /\ True /\ True /\ True /\ False).
Typeclasses eauto := debug.
Time try apply _. (* 2.148s *)
