coq-club - Re: [Coq-Club] Proof Irrelevance <-> Function Extensionality?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proof Irrelevance <-> Function Extensionality?
  • Date: Tue, 20 Dec 2016 03:24:27 -0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-ua0-f179.google.com
  • Ironport-phdr: 9a23:rooYhx9LD6P+SP9uRHKM819IXTAuvvDOBiVQ1KB+1OwcTK2v8tzYMVDF4r011RmSDN6dtKMP0bee8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkImbtjyT4XVloG80/2405zVeQRBwjSnMp1oKxDjkQzVt8Beu4pkJasrgk/VuHpOdOlM7WhzY02ahBb94Mis+5gl/ihN7aFyv/VcWLn3KvxrBYdTCy4rZjg4
I guess more simply you could skip thinking about predext altogether and just consider propext.
On Dec 20, 2016 3:11 AM, "Talia Ringer" <tringer AT cs.washington.edu> wrote:
A friend recently made a pretty good argument that you can have predext without funext (which makes sense), so I think that would be the easiest metatheoretic way to show you can't prove proof irrelevance -> funext [predext -> propext -> proof irrelevance, so if proof irrelevance -> funext, then predext -> funext.] But I haven't actually formalized his argument yet, and it's 3 AM here so I likely won't get to think about this more tonight.
The other direction strikes me as inherently not true otherwise UA would be inconsistent, but I also get really confused about how Prop interacts with univalent formalizations of Coq, so I could be off the mark.
On Dec 20, 2016 2:30 AM, "Bas Spitters" <b.a.w.spitters AT gmail.com> wrote:
Without really thinking about it, I guess the following techniques
should work to show that neither is provable:
http://www.pédrot.fr/articles/cpp2017.pdf
On Tue, Dec 20, 2016 at 3:44 AM, Abhishek Anand
<abhishek.anand.iitg AT gmail.com> wrote:
> Without using any axiom, can one prove either of the following?
> 1) Proof Irrelevance -> Function Extensionality
> 2) Function Extensionality -> Proof Irrelevance
> If not, is there a meta-theoretic argument about the unprovability of both
> of them?
> Thanks,
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
