- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is Coq SN?
- Date: Thu, 22 Dec 2016 14:36:08 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabriel.scherer AT gmail.com; spf=Pass smtp.mailfrom=gabriel.scherer AT gmail.com; spf=None smtp.helo=postmaster AT mail-it0-f52.google.com
- Ironport-phdr: 9a23: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
- [a machine formalized proof] is extremely tough, given the technical complexities involved, and the Godelian meta-theoretical issues (certainly something will have to be assumed as an axiom).
On a practical level, I have tried to do mechanized proofs of simpler systems in the past and I my personal impression was that the lack of induction-recursion made Coq unsuitable for formalization of universe hierarchies. This is one of the reason why I am very happy to hear that Matthieu Sozeau is working on induction-recursion. Of course, adding it worsens the problem of "mecha-meta-theoretizing the whole of Coq", but I think that having a system tomorrow in which the whole of today's situation can be exposed would be very valuable nonetheless.
On Thu, Dec 22, 2016 at 2:27 PM, roux cody <cody.roux AT gmail.com> wrote:
CodyBest,Hope this helps give the high overview,My constant call is for a more thorough exploration of the abstract structure of such proofs, so we can clearly separate it into combinatorial considerations + a model construction, which may be more tractable. There's a bunch of work on this as well, including the whole sub-field about normalization-by-evaluation, but CiC + universes seems a bit out of reach for now with such techniques, and again, writing down the whole construction is extremely tedious and error prone.- Such a proof is extremely tough, given the technical complexities involved, and the Godelian meta-theoretical issues (certainly something will have to be assumed as an axiom).- The above works are extremely technical and hard to fully check, this seems to be begging for a machine formalized proof.- There are a few papers which prove normalization of various fragments and variants of Coq. However, I know of none that handle CiC + Impredicative Prop + Universes + Large Elimination (don't even ask about impredicative set!). I can try to list them if required, but I always worry about forgetting a crucial one.- We should be trying to have a reasonable meta-theory anyways.- It's extremely difficult for the theory to keep up with the practical demands of the system.As the discussed example (and the example discussed last week) shows, Gallina/Coq is *not* SN, though as far as we know it *is* WN, which is enough for consistency.This issue comes up regularly on the list, and I believe that the summary is as follows:On Thu, Dec 22, 2016 at 8:10 AM, Bas Spitters <b.a.w.spitters AT gmail.com> wrote:This page refers to an example showing that Coq is not SN (due to the
guard condition).
https://coq.inria.fr/cocorico/CoqTerminationDiscussion
However, this (unpublished) report claims that CiC (with Prop and
universes) is SN.
http://csweb.rice.edu/uploadedFiles/Computer_Science/Research/Tech_Reports/TR11-01.pdf
Uniform Logical Relations - Eddy Westbrook
Has there been any progress on this? It would be good to update the
wiki/FAQ with this information.
- [Coq-Club] Is Coq SN?, Bas Spitters, 12/22/2016
- Re: [Coq-Club] Is Coq SN?, roux cody, 12/22/2016
- Re: [Coq-Club] Is Coq SN?, Gabriel Scherer, 12/22/2016
- Re: [Coq-Club] Is Coq SN?, Bas Spitters, 12/23/2016
