- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Dealing with equalities in dependent types
- Date: Fri, 20 Jan 2017 17:24:19 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=anton.a.trunov AT gmail.com; spf=Pass smtp.mailfrom=anton.a.trunov AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f46.google.com
- Ironport-phdr: 9a23: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
Hi Klaus,
FWIW, there is a function `cast`, defined in
https://coq.inria.fr/library/Coq.Vectors.VectorEq.html
Here is another take on `vmap_map`:
From Coq Require Import Vector List.
Lemma vmap_map : forall {A B} {f : A -> B} {v: list A},
Vector.map f (Vector.of_list v) = cast (Vector.of_list (map f v))
(map_length _ _).
Proof.
intros A B f v.
generalize (map_length f v).
induction v; intro.
- reflexivity.
- now simpl; rewrite <- IHv.
Qed.
Kind regards,
Anton
> On 20 Jan 2017, at 16:34, Dominique Larchey-Wendling
> <dominique.larchey-wendling AT loria.fr>
> wrote:
> Hi Klaus,
> The eq_cong term you define already exists in the library
> (possibly with the parameters in a different order), it
> is the recursion principle of equality:
> eq_rect
> You need to open eq_cong (Defined instead of Qed) to be able
> to compute with it.
> The problem with dependent types is that, unless you are
> very careful and very modest in your expectations, you are
> rapidly confronted with having to compute with proof terms.
> But this is basically a nightmare for at least two reasons:
> 1/ proofs are usually much more complicated than programs
> 2/ Coq is specifically designed to be as much as proof
> irrelevant as it can without additional axioms. Thus
> all the proof terms are opaque and you cannot compute
> with them ... so basically, for computing with proofs,
> you have to rewrite and open all the proofs you use in
> the standard library ...
> Notice that when the dependent parameter is of a type with
> a decidable equality, or simply has unique identity proofs,
> then you might be able to avoid point 2) (opening all
> proof terms) as is done in the following solution to
> your problem.
> Welcome in the wonderful world on dependent types !!!!
> Best regards,
> Dominique
> Require Import Arith List Vector Eqdep_dec.
> Fact uip_nat (n m : nat) (H1 H2 : n = m) : H1 = H2.
> Proof.
> apply UIP_dec, eq_nat_dec.
> Qed.
> Section eq_rect.
> Variables (A : Type) (P : A -> Type).
> Fact eq_rect_sym x tx y (H : x = y) ty :
> ty = eq_rect _ P tx _ H -> eq_rect _ P ty _ (eq_sym H) = tx.
> Proof.
> subst; auto.
> Qed.
> Fact eq_rect_trans x y z (tx : P x) (ty : P y) (tz : P z) (H1 : x = y)
> (H2 : y = z) :
> eq_rect _ P (eq_rect _ P tx _ H1) _ H2 = eq_rect _ P tx _ (eq_trans
> H1 H2).
> Proof.
> subst; auto.
> Qed.
> End eq_rect.
> Fact S_fun (n m : nat) : n = m -> S n = S m.
> Proof. intros []; auto. Defined.
> Fact eq_rect_cons A n x (v : t A n) m (H : n = m) :
> cons A x m (eq_rect _ (t A) v _ H) = eq_rect _ (t A) (cons A x n v)
> _ (S_fun _ _ H).
> Proof.
> subst; auto.
> Qed.
> Section vmap_map.
> Variables (A B : Type) (f : A -> B).
> Lemma vmap_map (l: list A) :
> Vector.map f (Vector.of_list l) = eq_rect _ (t B) (of_list (List.map
> f l)) _ (map_length f l).
> Proof.
> induction l as [ | x l IHl ]; simpl.
> generalize (map_length f (@List.nil A)).
> simpl; intros H1.
> rewrite uip_nat with (H1 := H1)
> (H2 := eq_refl); auto.
> rewrite IHl, eq_rect_cons; f_equal.
> apply uip_nat.
> Qed.
> End vmap_map.
> Le 20/01/2017 à 11:45, Klaus Ostermann a écrit :
>> I want to state (and prove) a lemma that conversion of
>> lists to vectors commutes with mapping.
>> Hence my lemma should look something like this:
>> Lemma vmap_map: forall {A B}{f : A -> B}{ l: list A},
>> Vector.map f (Vector.of_list l) = Vector.of_list (map f l).
>> This lemma is not accepted by Coq because:
>>> The term "Vector.of_list (map f l)" has type "Vector.t B (length (map
>> f l))"
>>> while it is expected to have type "Vector.t B (length l)".
>> There's a lemma in the standard library, which proves the required
>> equality, namely map_length:
>> map_length
>> : forall (A B : Type) (f : A -> B) (l : list A),
>> length (map f l) = length l
>> But how can I tell Coq that it should accept my lemma due to map_length?
>> One thing I tried was to reformulate the lemma using an explicit auxiliary
>> congruence lemma:
>> Lemma eq_cong: forall {A} {x : A} {y : A} P, x = y -> P x -> P y.
>> With this auxiliary Lemma, I can reformulate map_vmap in such a way
>> that Coq accepts the lemma:
>> Lemma vmap_map: forall {A B}{f : A -> B}{ v: list A},
>> Vector.map f (Vector.of_list v) = eq_cong (Vector.t B) (map_length f v)
>> (Vector.of_list (map f v)).
>> However, it's no longer the same lemma, and it's awkward to use.
>> Presumably I'm missing something very obvious, but I'd be grateful for
>> suggestions.
>> Klaus
- [Coq-Club] Dealing with equalities in dependent types, Klaus Ostermann, 01/20/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Dominique Larchey-Wendling, 01/20/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Anton Trunov, 01/20/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Klaus Ostermann, 01/20/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Emilio Jesús Gallego Arias, 01/20/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Emilio Jesús Gallego Arias, 01/21/2017
- Re: [Coq-Club] Dealing with equalities in dependent types, Vadim Zaliva, 01/21/2017
