- To: Randy Pollack <rpollack0 AT gmail.com>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Anomaly: Uncaught exception Not_found. Please report.
- Date: Wed, 25 Jan 2017 12:09:42 +0100
Hi Randy,
This is bug #4335 [1] where you can follow the discussion. This is
related to native compilation so a quick workaround is to configure
coq with native compilation disabled.
Best,
Hugo
[1] https://coq.inria.fr/bugs/show_bug.cgi?id=4335
On Mon, Jan 23, 2017 at 05:56:57PM +0000, Randy Pollack wrote:
> Consider the following two files. Coq 8.5pl1 with ProofGeneral fails
> to load file_XXX.v
> The definitions are just to make the example non-trivial, but the
> [Require] seem to be relevant.
> BTW, I tried to log in to Bugzilla, but failed.
> --Randy
> =====file_XXX.v=======================
> Module XXX.
> Require Bool.
> Load file_YYY.
> Export YYY.
> Definition tt := true.
> End XXX.
> ------file_YYY.v---------------------
> Module YYY.
> Definition ff := false.
> End YYY.
- [Coq-Club] Anomaly: Uncaught exception Not_found. Please report., Randy Pollack, 01/23/2017
- Re: [Coq-Club] Anomaly: Uncaught exception Not_found. Please report., Hugo Herbelin, 01/25/2017
