coq-club - Re: [Coq-Club] Record sort
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Record sort
  • Date: Sat, 28 Jan 2017 11:04:54 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=janno AT mpi-sws.org; spf=Pass smtp.mailfrom=janno AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23:CHJ+9hChunParPseaYZRUyQJP3N1i/DPJgcQr6AfoPdwSP38pMbcNUDSrc9gkEXOFd2CrakV16yL4uu4BiRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2as8Pi3OervpbXfg9ghTynYLo0Ig/lgx/Ws5w0iI0nDaIw1BbT6lhBev9b3ys8J1uVmRHU49+xuYV86GJXof13pJ0IarnzY6ltFe8QNz8hKW1gvMA=
I think Coq always tries to find the smallest type possible for records (and inductives?), mostly ignoring the annotation given by the user.
Related to this is the following example, which can be very annoying when doing meta programming:
Record R (P : Prop) : Type := { f : P -> P }.
Check R.
(* R : Prop -> Prop *)
The elim restriction does not apply to these types. The record can be used as if it had the annotated type. However, typeclasses and canonical structures defined for "Type"s won't trigger.
Best,
Jan-Oliver
On 01/28/2017 01:19 AM, Vadim Zaliva wrote:
I do not understand why when I define a Record in sort "Type" it ends up in
"Set"?
Welcome to Coq 8.6 (January 2017)
Coq < Record R (P: nat -> Prop) : Type := {f: nat -> nat}.
R is defined
f is defined
Coq < Check R.
R
: (nat -> Prop) -> Set
Vadim
CMU ECE PhD candidate
Mobile: +1(510)220-1060
