coq-club - Re: [Coq-Club] The typing of total recursive functions in Coq (via the untyped Lambda calculus)
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] The typing of total recursive functions in Coq (via the untyped Lambda calculus)
  • Date: Tue, 7 Feb 2017 15:59:28 +0100
  • Organization: LORIA
Now I do understand the reason for this Acc_intro_generator ...
I have another question regarding "singleton elimination".
As explained earlier, it is not needed for well-founded recursion.
It is not need either for False_rect elimination (I agree
it is more "void" than "singleton" elimination):
Fixpoint False_rect_prog (H : False) : forall X, X :=
False_rect_prog (match H with end).
So my question is: does "singleton elimination" add some
expressivity to the CIC/Coq or is it just introduced in the
calculus as a convenience/shortcut ?
D.
Le 06/02/2017 à 14:10, Matthieu Sozeau a écrit :
> The partial way out of this issue is to put some fuel (a large number of
> Acc_intro constructors) in front of your opaque proof, as is done by
> Wf.Acc_intro_generator
> On Mon, Feb 6, 2017 at 12:01 PM Dominique Larchey-Wendling
> <mailto:dominique.larchey-wendling AT loria.fr>>
> wrote:
> Le 06/02/2017 à 08:55, Gaetan Gilbert a écrit :
> >>But if you use the second method (acc_rect_alt), it seems to me that
> > there would be no need to advance in the computation of the
> > accessibility proof while reducing a term defined by induction on that
> > predicate, even within Coq internal evaluation strategies. I am not
> > sufficiently aware of Coq's internal evaluation mechanism to be
> certain
> > of that but I do not think that added axioms would block the
> evaluation
> > because the proof of accessibility is never needed to reduce the term.
> > It might however saturate the memory if it is never reduced ...
> > Fixpoints only unfold if the principal argument is a constructor. For
> > acc_rec_alt the principal argument is the (Hx : acc x) so it needs
> to be
> > reduced.
> > This is because otherwise you would get an infinite reduction
> > acc_rec_alt x Hx ↦ f x (fun y Hy => acc_rec_alt ...)
> > ↦ f x (fun y Hy => f y (fun z Hz => acc_rec_alt ...))
> Ok this is a bit unfortunate ... it means anything defined with
> the Fix operator or by induction over a predicate will almost
> certainly have its evaluation blocked because most proof terms
> are Opaque in Coq ... this is not specific to this particular
> fixpoint computation.
> D.
