- To: coq-club <coq-club AT inria.fr>, Coqdev <coqdev AT inria.fr>
- Subject: Re: [Coq-Club] efficiently reducing away mentions of a variable
- Date: Mon, 13 Feb 2017 15:31:45 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f176.google.com
- Ironport-phdr: 9a23:WjVLBRHWBXPM+MB6vqfLtJ1GYnF86YWxBRYc798ds5kLTJ75p8SwAkXT6L1XgUPTWs2DsrQf2raQ4vurBjBIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/iwguu14tjYZxhCzG62Zqo3JxGrpy3QsNMXiM1sMPB1gjDOu3dFZawCzmRxKV+Ntxf6/Ma5upB5pXd+ofUkoutJTbn6fqklBYdfHjkvLihh4cT3qRDGZQ6G+mcVVyMRiBUeUFuN1w3zQpqk6niyjeF6wiTPZcA=
Hi Abhishek,
I think the only existing versions of shrinking like this in Coq's codebase do not involve any reduction but work on a given, fixed term (and are hence much simpler).
Best,
-- Matthieu
On Fri, Feb 10, 2017 at 9:22 PM Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
I have a parametricity-like program translation that produces theorems and their proofs.Often these theorems have hypotheses that are not needed in their proofs,in the sense that after fully normalizing the proof, the variable denoting the hypothesis is noteven mentioned in the proof. I want to identify and eliminate such hypothesisfrom the theorem's statement.However, naively doing the normalization blows up on bigger examples.Is there a mechanism (e.g. a function in Coq's sources, or a tactic)that can take a term in a context and do the reduction less naively in order to eliminate mentionsa given variable? For example, it can ignore subterms that don't even mention the variable.Even If there isn't a function that does exactly what I want, it would be helpful for me toget pointers to functions that I could use in my implementation.Thanks,-- Abhishekhttp://www.cs.cornell.edu/~aa755/
- [Coq-Club] efficiently reducing away mentions of a variable, Abhishek Anand, 02/10/2017
- Re: [Coq-Club] efficiently reducing away mentions of a variable, Matthieu Sozeau, 02/13/2017
- Re: [Coq-Club] efficiently reducing away mentions of a variable, Jacques-Henri Jourdan, 02/13/2017
- Re: [Coq-Club] efficiently reducing away mentions of a variable, Enrico Tassi, 02/14/2017
- Message not available
- Re: [Coq-Club] [coqdev] efficiently reducing away mentions of a variable, Abhishek Anand, 02/14/2017
- Re: [Coq-Club] [coqdev] efficiently reducing away mentions of a variable, Pierre-Marie Pédrot, 02/14/2017
