- From: Cristóbal Camarero Coterillo <nakacristo AT hotmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] injectivity of inductive type implies False
- Date: Mon, 27 Feb 2017 18:26:31 +0000
- Accept-language: es-ES, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nakacristo AT hotmail.com; spf=Pass smtp.mailfrom=nakacristo AT hotmail.com; spf=None smtp.helo=postmaster AT BLU004-OMC4S37.hotmail.com
- Ironport-phdr: 9a23:LH3ADxH+xrYfBX1gU/T6SJ1GYnF86YWxBRYc798ds5kLTJ75ps6wAkXT6L1XgUPTWs2DsrQf2reQ6f6rADVZqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LX48JrKJg5MmTCVYLVoLRzwox+b/p0dhpInIaIswDPIpGFJcqJY3zU7C0iUmkPX/Mar4AVp+iBnkPsk/tRNS6LNVKMkQKZZCDAhezQz7c7ivgPCVheIznsbTmAfkx4OCA/AukKpFqztuzf347IukBKROtf7GOg5
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Some time ago I found this inductive type plus axiom of injectivity that implies False with the help of
dependent_unique_choice and classic.
Inductive some {T:Type} (t:T) : Type:=
|some_single: some t
|some_more: Type -> some t-> some t.
Axiom some_inj: forall (T:Type) (x y:T), some x=some y -> x=y.
|some_single: some t
I had really expected that some being a newly introduced type, it could be made injective. I mean, it is alike if two vectors are equal they must have the same dimension.
I have attached the proof of False.
Interestingly if I use
Inductive single {T:Type} (t:T) : Type:=
|single_intro: single t.
Axiom single_inj: forall (T:Type) (x y:T), single x=single y -> x=y.
then all I get is a Universe Inconsistency, which is what I would expect in both cases.
Best regards,
--Cristóbal Camarero
Require Import Classical. Require Import ClassicalChoice. Definition injective (A B:Type) (f:A->B) := forall (x y:A), @eq B (f x) (f y) -> @eq A x y. Definition surjective (A B:Type) (f:A->B) := forall y:B, @ex A (fun x:A=> @eq _ (f x) y). Inductive cardinal:Type := |cardinal_intro : forall (S:Type->Prop), cardinal. Definition cardinal_le:= fun A B:Type => @ex (A->B) (fun f:A->B => injective A B f). (*not necessary*) (*Definition cardinal_eq:= fun A B:Type => and (cardinal_le A B) (cardinal_le B A).*) Inductive some {T:Type} (t:T) : Type:= |some_single: some t |some_more: Type -> some t-> some t. Axiom some_inj: forall (T:Type) (x y:T), some x=some y -> x=y. (* Using Inductive single {T:Type} (t:T) : Type:= |single_intro: single t. Axiom single_inj: forall (T:Type) (x y:T), single x=single y -> x=y. would lead to an universe inconsistency *) (* con tipos ordenados (y algo mas) deberia poderse hacer *) Theorem injective_into_Type: forall (T:Type), exists f:T->Type, injective T Type f. Proof. intros. exists some. intros x y EQ. apply some_inj. exact EQ. Qed. Definition func_inverse (A B:Type) (f:A->B) (g:B->A) := forall x:A, @eq A (g (f x)) x. Definition image (A B:Type) (f:A->B) (y:B) := @ex A (fun x:A=> @eq B (f x) y). (*Definition map (A B:Type) (f:A->B) (S:A->Prop) (y:B) := @ex A (fun x:A=> and (S x) (@eq B (f x) y)).*) Lemma image_trivial: forall (A B:Type) (f:A->B) (x:A), image A B f (f x). Proof. intros. unfold image. apply ex_intro with (x:=x). apply eq_refl. Qed. (* Lemma map_trivial: forall (A B:Type) (f:A->B) (S:A->Prop) (x:A), S x -> map A B f S (f x). Proof. intros. unfold map. apply ex_intro with (x:=x). apply conj. exact H. apply eq_refl. Qed. *) Theorem leibnitz: forall (T:Type) (x y:T), x=y -> forall P:T->Prop, P x -> P y. Proof. intros. rewrite H in H0. exact H0. Qed. Theorem cardinal_large: forall T:Type, cardinal_le T cardinal. Proof. intros. apply ex_intro with (x:=fun t:T=> cardinal_intro (fun X:Type=> eq X (some t))). intros x y EQ. inversion EQ. apply f_equal with (f:=fun t=>t (some x) ) in H0. assert(L:=leibnitz _ _ _ H0). assert(H: some x=some x). auto. apply L with (P:=fun x=>x) in H. clear EQ H0 L. apply some_inj. exact H. Qed. Theorem Cantor: forall (T:Type) (f:T->(T->Prop)), surjective T (T->Prop) f -> False. Proof. intros T f SUR. specialize(SUR (fun x:T=> not (f x x) )). revert SUR. apply ex_ind. intros. apply f_equal with (f:=fun t=>t x) in H. assert(C:=classic (f x x)). assert(L:=leibnitz _ _ _ H). apply (L (fun t=>or t _)) in C. assert(NF: not (f x x)). destruct C;auto. apply NF. rewrite H. exact NF. Qed. Theorem injective_unique_preimage: forall (A B:Type) (f:A->B), injective A B f-> forall y:B, image A B f y -> @ex A (@unique A (fun x:A=> @eq B (f x) y)). Proof. intros. unfold image in H0. revert H0. apply ex_ind. intros x Hxy. apply ex_intro with (x:=x). unfold unique. apply conj. exact Hxy. intros. apply H. apply eq_sym in Hxy. rewrite<- Hxy. rewrite H0. apply eq_refl. Qed. Theorem injective_inverse: forall (A B:Type) (f:A->B) (dummy:A), injective A B f -> @ex (B->A) (fun g:B->A=> and (surjective B A g) (func_inverse A B f g) ). Proof. (* see https://proofwiki.org/wiki/Injection_has_Surjective_Left_Inverse_Mapping/Proof_1 *) intros. set(R:=fun (y:B) (x:A) => and (image A B f y -> @eq B (f x) y ) (not (image A B f y)->@eq A x dummy)). assert(UC:=unique_choice B A R). rename H into INJ. assert(PRE:(forall x : B, @ex A (@unique A (fun y : A => R x y)))). intros y. unfold R. assert(IUP:=injective_unique_preimage A B f INJ y). assert(C:=classic (image A B f y)). revert C. apply or_ind. intros IMAG. specialize(IUP IMAG). revert IUP. apply ex_ind. intros x. unfold unique. apply and_rect. intros Hxy Huniquex. apply ex_intro with (x:=x). apply conj. apply conj. intros. exact Hxy. intros. apply False_rect. apply H. exact IMAG. intros x'. apply and_rect. intros. apply Huniquex. apply H. exact IMAG. intros NIMAG. apply ex_intro with (x:=dummy). unfold unique. apply conj. apply conj. intros. apply False_rect. apply NIMAG. exact H. intros. apply eq_refl. intros x. apply and_rect. intros. apply eq_sym. apply H0. exact NIMAG. specialize(UC PRE). revert UC. apply ex_ind. intros g Hg. apply ex_intro with (x:=g). apply conj. - unfold surjective. intros x. apply ex_intro with (x:=f x). unfold R in Hg. specialize(Hg (f x)). revert Hg. apply and_rect. intros. apply INJ. apply H. apply image_trivial. - unfold func_inverse. intros. unfold R in Hg. specialize(Hg (f x)). revert Hg. apply and_rect. intros. apply INJ. apply H. apply image_trivial. Qed. Theorem bad: False. Proof. assert(H:=cardinal_large (cardinal->Prop)). destruct H as [f INJ]. assert(X:=injective_inverse _ _ f (fun x=>True) INJ). destruct X as [g [SUR INV]]. apply Cantor with (f:=g). exact SUR. Qed. Print Assumptions bad.
- [Coq-Club] injectivity of inductive type implies False, Cristóbal Camarero Coterillo, 02/27/2017
- Re: [Coq-Club] injectivity of inductive type implies False, Guillaume Melquiond, 02/28/2017
- Re: [Coq-Club] injectivity of inductive type implies False, Chung-Kil Hur, 02/28/2017
