- To: coq-club AT inria.fr
- Subject: [Coq-Club] adventures in setoid_rewrite
- Date: Mon, 27 Feb 2017 22:48:39 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=Pass smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-wm0-f41.google.com
- Ironport-phdr: 9a23:VyX+shdP/5VEt2buE1GnyMS8lGMj4u6mDksu8pMizoh2WeGdxc28Yx7h7PlgxGXEQZ/co6odzbGH7ua6BidZuczJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbUekBDgCe3SbJ0NhS/6wvL5ecMho43FK89yx6BkHJMevpfjTd2N1uXngj1zsy14dhu/zkG6KFpzNJJTaivJ/dwdrdfFjlza20=
Hi!
Since I am working with setoid_rewriting tactic a lot I am trying to get a better understanding how it works to be able to resolve the problems. For instance, I have noticed changes in behavior between Coq 8.5 and 8.6. Often, type class resolution for Proper instances during setoid_rewrite runs amok and I need to be able to debug such situations. I found options which enable logging, but my logs are huge and hard to read. I even wrote a small script which visualizes them via graphvis. On some examples it works reasonably well, producing output like this:
However, I could not make sense of log files for fairly simple cases. Here is an example:
Require Import Relations Setoid Morphisms.
Parameter Foo: Type.
Parameter R: relation Foo.
Parameter bar: Foo -> Foo -> Foo.
Instance R_reflexive: Reflexive R. Admitted.
Instance R_trasitive: Transitive R. Admitted.
Instance bar_proper: Proper ((R) ==> (R) ==> (R)) (bar). Admitted.
Example Test (a b c: Foo):
R a b -> R (bar c a) (bar c b).
Proof.
intros H.
Set Typeclasses Debug.
Set Typeclasses Debug Verbosity 2.
Set Printing All.
setoid_rewrite H.
The very first message mentions 3 goals:
Debug: Starting resolution with 3 goal(s) under focus and 0 shelved goal(s) in only_classes mode, unbounded
Not sure what these goals are, but hopefully they will reveal themselves as we proceed. Then, it proceeds to try what I assume is the first goal:
Debug: 1: looking for (@Proper (forall _ : Foo, Foo) (@respectful Foo Foo R ?r) (bar c)) with backtracking
Trying bunch of tactics, each of them failing with an Anomaly:
Debug: 1.1: exact bar_proper on
(@Proper (forall _ : Foo, Foo) (@respectful Foo Foo R ?r) (bar c)) failed with
Anomaly: Uncaught exception Pretype_errors.PretypeError(_, _, _). Please report at
Debug: 1.1: simple apply @Morphisms_Prop.well_founded_morphism on
Error:
After exhausting all tactics it has to try (failed "1.1" leaves) it suddenly reports that it restarting resolutions with just one goal (not 3 anymore!). Note it has the same level "1" as before and does not look like a subgoal.
Debug: Starting resolution with 1 goal(s) under focus and 0 shelved goal(s) in only_classes mode, unbounded
It is now looking for Params instance, not Proper. It is unclear where this comes from. The only mention of Params class I found is in LTAC "partial_application_tactic," but there is no record of its application in the log yet.
Debug: 1: looking for (@Params (forall (_ : Foo) (_ : Foo), Foo) bar ?H1) with backtracking
It looks like it immediately fails to resolve Param:
Debug: 1: no match for (@Params (forall (_ : Foo) (_ : Foo), Foo) bar ?H1)
, 0 possibilities
Now I would guess it has to proceed to a new goal. But there is no message "Starting resolution" like before, it just applies partial_applicatoin_tactic to the initial goal.
Debug: 1.1: (*external*) partial_application_tactic on
(@Proper (forall _ : Foo, Foo) (@respectful Foo Foo R ?r) (bar c)), 2 subgoal(s)
Probably my interpretation of these messages is pretty naive and I am just poking in the dark. Any advice or hints are greatly appreciated. I am also started to look at the Coq source code, but I am at early stages of understanding it and have not been able yet to connect where these messages are generated. I am starting to suspect that the log messages might be incomplete and it is not possible to reconstruct search tree from them alone.
P.S. I wish there is a way to disable typeclass resolution during setoid_rewrite and generate them as goals instead, letting the user to manually supply proofs.
CMU ECE PhD candidate
Mobile: +1(510)220-1060
- [Coq-Club] adventures in setoid_rewrite, Vadim Zaliva, 02/28/2017
- Re: [Coq-Club] adventures in setoid_rewrite, Jason Gross, 02/28/2017
- Re: [Coq-Club] adventures in setoid_rewrite, Vadim Zaliva, 02/28/2017
