coq-club - Re: [Coq-Club] Unicode tokens?
  • From: Clément Pit-Claudel <cpitclaudel AT gmail.com>
  • To: Ralf Jung <jung AT mpi-sws.org>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unicode tokens?
  • Date: Sun, 12 Mar 2017 08:52:07 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cpitclaudel AT gmail.com; spf=Pass smtp.mailfrom=cpitclaudel AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f171.google.com
  • Ironport-phdr: 9a23:PDg4Zxb/QdalHOZ8tuTCSlv/LSx+4OfEezUN459isYplN5qZpc+7bnLW6fgltlLVR4KTs6sC0LuL9f26EjBcqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2ap42N2uuz45zeZRlTzHr4OOsqbUb+kQKEjMASj8NAN6A+gk/Lv31HU+FOxCZzOknVmAzzsIP495l6ti9UpvgJ9shaUKy8cb5rY6ZfCWENN+Ew6cv3giHCUU6k4nIBXmgS2k5DGwnZ5xXzQ5v8tgP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNstTiP0sE=
On 2017-03-12 08:04, Ralf Jung wrote:
> This also helps with emacs 24:
Yup, this is more or less isomorphic to the snippet in company-coq's README
:) (though your particular mutation looks incorrect to me)
> ; Appending to the 'unicode list makes emacs unbearably slow.
> (set-fontset-font ft nil (font-spec :name "DejaVu Sans Mono"))
Can you post a message to https://debbugs.gnu.org/cgi/bugreport.cgi?bug=21028
about this ? I've been trying to get this bug fixed for a (long) while,
there is a patch, and all that's missing is evidence that the bug is worth
fixing, so independent reproduction helps bump its priority. Bonus points if
you test the patch at https://github.com/cpitclaudel/emacs , of course :)
> ; If we 'append this to all fontsets, it picks Symbola even for some
> cases where DejaVu could be used.
That's because your setup uses "nil" for the fontset, which means "don't use
DejaVu unless it's the only available option"
> Unfortunately, the behavior of these emacs fontset-lists is entirely
> non-intuitive,
That I do agree with :)
> But at least it's working, and not picking the bad TeX fonts.
Adding a regexp matching TeX fonts to face-ignored-fonts is a decent
alternative for that specific purpose, though of course your snippet above
does a lot more :)
Cheers,
Clément.
