- From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Both annoying things in one place
- Date: Mon, 13 Mar 2017 10:41:36 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Pass smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:zL89vRbGCFR9VTYs6DX+gUD/LSx+4OfEezUN459isYplN5qZpsuzbnLW6fgltlLVR4KTs6sC0LuL9f28EjRbqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1KRrJ7o4zFPmo39Cdv5KjTdnLF+PlhC66ca09pN57wxdvelk899HV+P0ZfJrHvRjED06PjVtt4XQvh7ZQF7X6w==
>1) No 'assert' tactics with transparent result. (Maybe I don't know the right way.)
You can use [simple refine (let x := _ : A in _)] instead of [refine. Unshelve. swap.]
See https://github.com/HoTT/HoTT/blob/master/theories/Basics/Overture.v#L856 to make it into a [transparent assert] tactic.
>2) Opaque proofs where one needs transparency. :(
le_unique from Arith is enough for this proof.
Gaëtan Gilbert
Require Import Omega.
Set Implicit Arguments.
Axiom PI: forall (P: Prop) (a b: P), a = b.
Structure bijection A B := {
bijF1: A -> B;
bijF2: B -> A;
_: forall x, bijF1 (bijF2 x) = x;
_: forall x, bijF2 (bijF1 x) = x
Definition fin n := { m | m < n }.
Definition finite A n := bijection A (fin n).
Example E1 a b (H: a <= b):
let A := { n | a <= n /\ n <= b }
in finite A (S b - a).
Proof.
intro A.
refine (let f := (_ : A -> fin (S b - a)) in _). Unshelve. all:swap 1 2.
intros [n [H1 H2]]. exists (n - a). intuition.
refine (let g := (_: fin (S b - a) -> A) in _). Unshelve. all:swap 1 2.
intros [n H0]. exists (n + a). intuition.
exists f g.
intros [n H0]. simpl. f_equal. (* apply PI. *)
Admitted.
Require Import Omega. Set Implicit Arguments. Structure bijection A B := { bijF1: A -> B; bijF2: B -> A; _: forall x, bijF1 (bijF2 x) = x; _: forall x, bijF2 (bijF1 x) = x }. Definition fin n := { m | m < n }. Definition finite A n := bijection A (fin n). Lemma exist_irr {A:Type} (P:A->Prop) (H : forall x (y y' : P x), y = y') : forall x x' y y', x = x' -> exist P x y = exist P x' y'. Proof. intros x x' y y' e;destruct e;f_equal;apply H. Qed. Example E1 a b (H: a <= b): let A := { n | a <= n /\ n <= b } in finite A (S b - a). Proof. intro A. simple refine (let f := (_ : A -> fin (S b - a)) in _). intros [n [H1 H2]]. exists (n - a). intuition. simple refine (let g := (_: fin (S b - a) -> A) in _). intros [n H0]. exists (n + a). intuition. exists f g. intros [n H0]. simpl. apply exist_irr;intuition. apply le_unique. intros [n [H0 H1]]. simpl. apply exist_irr;intuition. destruct y,y';f_equal;apply le_unique. Defined.
- [Coq-Club] Both annoying things in one place, Ilmārs Cīrulis, 03/13/2017
- Re: [Coq-Club] Both annoying things in one place, Ilmārs Cīrulis, 03/13/2017
- Re: [Coq-Club] Both annoying things in one place, Gaetan Gilbert, 03/13/2017
