- To: coq-club AT inria.fr
- Subject: [Coq-Club] Special Issue of MSCS---Call for Papers
- Date: Sun, 2 Apr 2017 22:56:35 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gopalan.nadathur AT gmail.com; spf=Pass smtp.mailfrom=gopalan.nadathur AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f51.google.com
- Ironport-phdr: 9a23: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
Call for Papers
Special Issue of Mathematical Structures in Computer Science
in Celebration of the Sixtieth Birthday of Dale Miller
Papers are invited to a special issue of Mathematical Structures in Computer Science, a journal published by Cambridge University Press. This special issue is being collated in celebration of the sixtieth birthday of Professor Dale Miller. To be appropriate for this collection, papers must be broadly related to one or more of the areas that have been spanned by the work of Professor Miller to-date. These areas include structural proof theory, proof search and computation, foundations of logic programming, higher-order unification, reasoning about relational specifications and certification of proofs. This list is meant to be illustrative and is not exhaustive; if you are interested in submitting a paper and would like to ascertain its relevance to the theme of the special issue, please feel free to contact the editors of the issue.
Papers that are submitted for consideration of publication must be prepared in LaTeX and should use the MSCS style file that can be downloaded from
ftp.cup.cam.ac.uk.
Please also follow the layout and other manuscript format related instructions with the exception of double spacing that you will find at
http://z.umn.edu/mscsformat.
Manuscripts should also be limited to about 25 pages. While this is not a hard constraint, the reason why a paper exceeds this limit must be apparent to the editors from an inspection of its content, else it may be declined without review.
To ensure timeliness of publication, strict deadlines and an expedited reviewing process will be followed in the preparation of this special issue. To be considered for publication, manuscripts must be submitted by May 31, 2017. The first round of reviews will be completed by July 31, 2017. Revised versions of manuscripts that are deemed to be of acceptable quality will be due by August 21, 2017 and final acceptance decisions will be made by September 11, 2017.
To submit a manuscript to the special issue, please use the ScholarOne site for MSCS at
https://mc.manuscriptcentral.com/mscs.
Once you are at this site, you will need to create an account if you do not have one already. Once you are logged in, select the "Author" tab and follow the instructions. At the end of the page, under the "Special Issue" heading, select "Miller Festschrift" prior to submission. Please note that at this stage we will need only a PDF file prepared as indicated above. The LaTeX source will be required after the manuscript has been accepted.
Regards,
David Baelde (david.baelde AT lsv.ens-cachan.fr)
Amy Felty (afelty AT eecs.uottawa.ca)
Gopalan Nadathur (gopalan AT cs.umn.edu)
Alexis Saurin (alexis.saurin AT irif.fr)
- [Coq-Club] Special Issue of MSCS---Call for Papers, Gopalan Nadathur, 04/03/2017
