- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using vm_compute and reflexivity
- Date: Sat, 22 Apr 2017 23:39:12 +0200
On 04/22/2017 11:35 PM, Kenneth Roe wrote:
This solution does not quite work. This does indeed apply vm_compute to the ?X
term. However, this code will substitute the result or the existential variable.
The “reflexivity” tactic will then apply “simpl" to the original “3+4” term.
The “3+4” term needs to be evaluated exclusively by vm_compute and nothing else.
That's the point of the vm_cast, the reflexivity will be checked by vm_compute.
Laurent
- [Coq-Club] Using vm_compute and reflexivity, Kenneth Roe, 04/22/2017
- Re: [Coq-Club] Using vm_compute and reflexivity, Laurent Thery, 04/22/2017
- Re: [Coq-Club] Using vm_compute and reflexivity, Kenneth Roe, 04/22/2017
- Re: [Coq-Club] Using vm_compute and reflexivity, Kenneth Roe, 04/23/2017
- Re: [Coq-Club] Using vm_compute and reflexivity, Laurent Thery, 04/23/2017
