coq-club - Re: [Coq-Club] Problem with constructive rewriting
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Problem with constructive rewriting
  • Date: Fri, 12 May 2017 18:23:11 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f176.google.com
  • Ironport-phdr: 9a23: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
What happens if you Set Printing Universes?  It sounds like this might be a bug...
On Fri, May 12, 2017, 1:32 PM John Wiegley <johnw AT newartisans.com> wrote:
In the code below I'm trying to develop a notion of "isomorphism" that allows
for rewriting. However, I'm getting a strange error that I can't yet make any
sense of:
    Error: Illegal application:
    The term "@flip" of type "∀ A B C : Type, (A → B → C) → B → A → C"
    cannot be applied to the terms
     "Type" : "Type"
     "Type" : "Type"
     "Type" : "Type"
     "arrow" : "Type → Type → Type"
    The 4th term has type
     "Type@{Top.8164} → Type@{Top.8165} → Type@{max(Top.8164, Top.8165)}"
    which should be coercible to
     "Type@{max(Coq.Classes.CEquivalence.6, Top.4)}
      → Type@{max(Coq.Classes.CEquivalence.6, Top.4)} → Type@{Top.8166}".
If instead I use transitivity, the same proof passes easily.
Below is the test case, if anyone has any thoughts.
Thank you,
  John
Require Export
  Coq.Unicode.Utf8
  Coq.Program.Program
Close Scope nat_scope.
Notation "f ≈ g" := (equiv f g) (at level 79, only parsing).
Reserved Infix "~>" (at level 90, right associativity).
Reserved Infix "∘" (at level 40, left associativity).
Class Category := {
  ob : Type;
  uhom := Type : Type;
  hom : ob -> ob -> uhom where "a ~> b" := (hom a b);
  id {A} : A ~> A;
  compose {A B C} (f: B ~> C) (g : A ~> B) : A ~> C
    where "f ∘ g" := (compose f g);
  id_left  {X Y} (f : X ~> Y) : id ∘ f ≈ f;
  comp_assoc {X Y Z W} (f : Z ~> W) (g : Y ~> Z) (h : X ~> Y) :
    f ∘ (g ∘ h) ≈ (f ∘ g) ∘ h
Notation "X ~> Y" := (@hom _ X Y) (at level 90, right associativity).
Notation "f ∘ g" := (@compose _ _ _ _ f g).
Coercion ob : Category >-> Sortclass.
Class Isomorphism `{C : Category} (X Y : C) : Type := {
  to   :> X ~> Y;
  iso_to_from : to ∘ from ≈ id;
  iso_from_to : from ∘ to ≈ id
Ltac reassoc f :=
  repeat match goal with
    | [ |- context[(?F ∘ f) ∘ ?G] ] => rewrite <- (comp_assoc F f G)
    | [ |- context[f ∘ (?G ∘ ?H)] ] => rewrite (comp_assoc f G H)
    end.
Program Instance isomorphism_equivalence `{C : Category} :
  Equivalence Isomorphism.
Next Obligation.
  repeat intro.
  apply Build_Isomorphism with (to:=id) (from:=id);
  rewrite id_left; reflexivity.
Defined.
Next Obligation.
  repeat intro; destruct X.
  apply Build_Isomorphism with (to:=from0) (from:=to0); assumption.
Defined.
Next Obligation.
  repeat intro; destruct X, X0.
  apply Build_Isomorphism with (to:=to1 ∘ to0) (from:=from0 ∘ from1).
    | [ H : equiv (?F ∘ ?G) _
      |- context[(_ ∘ ?F) ∘ (?G ∘ _)] ] => reassoc F; rewrite H
      |- context[?F ∘ (?G ∘ _)] ] => reassoc F; rewrite H
      |- context[(_ ∘ ?F) ∘ ?G] ] => reassoc F; rewrite H
      |- context[?F ∘ ?G] ] => rewrite H
    | [ |- equiv ?F ?F ] => reflexivity
    | [ |- context[id ∘ ?F] ] => rewrite (id_left F)
    end.
  reassoc from1; rewrite iso_from_to1.
  rewrite id_left; assumption.
Defined.
Notation "X ≅ Y" := (@Isomorphism _ X Y) (at level 91).
Goal forall `{C : Category} {X Y Z : C} (f : Y ≅ Z) (g : X ≅ Y), X ≅ Z.
  intros.
  (* transitivity Y; auto. *)
  rewrite g.
John Wiegley                  GPG fingerprint = 4710 CF98 AF9B 327B B80F
http://newartisans.com                          60E1 46C4 BD1A 7AC1 4BA2
