- To: coq-club AT inria.fr
- Subject: [Coq-Club] Calling out to unification from a plugin
- Date: Tue, 23 May 2017 10:25:47 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-wm0-f42.google.com
- Ironport-phdr: 9a23:YeZPlBKSWOLn9q9+y9mcpTZWNBhigK39O0sv0rFitYgRLP7xwZ3uMQTl6Ol3ixeRBMOAuqwC1rWe8/i5HzdRvtDZ6DFKWacPfiFGoP1VpTBoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaz6FYHIksu4yf259YHNbAVUnjq9Zq55IAmroQnLuMQbhYpvJrwxxxbLv3BEf/hayX5yKV+dmxvx5N288IJ//yhVpvks69NOXaLmcqs3SrBVEC4oP2cp6sP1qBLNVxGP5nwSUmUXlhpHHQ3I5wzkU5nyryX3qPNz1DGVMsPqQ780Xy+i77pwRx/zlCgHLT85/3rJhcF2kalWvQiupx17w47TfYGVKP9zdb7TcN8GWWZMWNtaWipcCY2+coQPFfIMM+ZWoYf+ulUAswexCBK2C+/z0DJFnGP60bE43uknDArI3BYgH9ULsHnMstv6LqMSUeGvw6LV0TvDbvVW2Tjj54jSbxsspu2MXahxccrXxkkgCRnFg06Mpoz+JT+U2P4Cs3Ob7+phU+KvhHInqwZ3ojS12Mgjl5TJi5sTx1vZ9it52J44KN+3RUJhfNKoDptduzuZOodoWM8vTH9ktSAnwbMco5G7ZjIFyJE/yh7fdfOHd4+I7wrmVOmLIDd4gGtpeby6hxqu6ESgxOLxWteu3FZFqSpFldbMtnQT2BDJ9seHTf598l+g2TaJyQ/T9vlJLEI7mKbBNpIt3L49moAQvEjdBCP7l1v6gLeTdko+++io7+rnYq/hpp+ZL4J0lhv+MqUomsywH+s4KBMDUHSA+eim2rzs51b5QLVLjv0wnanZrJfaJcIBqqGnHgBVz54v6wyjADe+zNQYgX4HIUpZdxKAlojlIk3BIPTlDfikmFmsizdqx/XePrL7GJnNL37DkK3gfbln8UJcxhAznphj4MdfDahEK/buUGfwssbZB1k3KV+a2eHiXel00oIXEViOBKCUKuuGrUWJ4O0iOcGHf8kKsS39Kv4q+/noy3I1hAlOLuGSwZILZSXgTbxdKEKDbC+0jw==
Hi all,
I'm writing a Coq plugin that finds patches for small changes in theorems and proofs. Right now, there is a point in my tool where it would be very useful to query out to unification rather than reinvent the wheel. The unification problems I'm dealing with should be easy enough for Coq to solve most of the time.
- [Coq-Club] Calling out to unification from a plugin, Talia Ringer, 05/23/2017
- Re: [Coq-Club] Calling out to unification from a plugin, Jason Gross, 05/23/2017
- Re: [Coq-Club] Calling out to unification from a plugin, Abhishek Anand, 05/23/2017
- Re: [Coq-Club] Calling out to unification from a plugin, Emilio Jesús Gallego Arias, 05/24/2017
