coq-club - Re: [Coq-Club] Avoiding the use of JMeq_eq
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Avoiding the use of JMeq_eq
  • Date: Sat, 27 May 2017 15:34:59 +0200 (CEST)
You can avoid the detour via Eqdep_dec (which is axiom free though)
using pattern matching but the type is difficult to write in
"programming style" because of dependent pattern matching.
However, using "proof-style programming" (tactics), the type is
much easier to define/write. See the type definition RoofHom_inv_t
and the generated term.
Best,
Dominique
Inductive RoofObj : Type := RNeg | RZero | RPos.
Inductive RoofHom : RoofObj -> RoofObj -> Type :=
| IdNeg : RoofHom RNeg RNeg
| ZeroNeg : RoofHom RZero RNeg
| IdZero : RoofHom RZero RZero
| ZeroPos : RoofHom RZero RPos
| IdPos : RoofHom RPos RPos.
Definition RoofHom_inv_t : forall x y, RoofHom x y -> Prop.
Proof.
intros [] [] f.
exact (f = IdNeg).
exact False. (* Unused, any Prop is ok here *)
exact (f = ZeroNeg).
exact (f = IdZero).
exact (f = ZeroPos).
exact (f = IdPos).
Defined.
(* This is the term in programming style ... *)
Print RoofHom_inv_t.
Fact RoofHom_inv x y f : RoofHom_inv_t x y f.
Proof.
destruct f; reflexivity.
Qed.
Lemma RNeg_RNeg_id (f : RoofHom RNeg RNeg) : f = IdNeg.
Proof. exact (RoofHom_inv _ _ f). Qed.
Lemma RZero_RPos_id (f : RoofHom RZero RPos) : f = ZeroPos.
----- Mail original -----
> De: "Dominique Larchey-Wendling"
> À:
> Envoyé: Vendredi 26 Mai 2017 19:39:30
> Objet: Re: [Coq-Club] Avoiding the use of JMeq_eq
> Hi John,
> I would do it using an general inversion lemma ... easy to prove
> but more difficult to state ... and then use discriminate
> and uniqueness of identity proofs for your decidable type.
> Dominique
> Require Import Eqdep_dec.
> Fact RoofObj_dec (x y : RoofObj) : { x = y } + { x <> y }.
> Proof. decide equality. Qed.
> Fact UIP_RoofObj (x : RoofObj) (H : x = x) : H = eq_refl.
> Proof. apply UIP_dec, RoofObj_dec. Qed.
> Fact RoofHom_inv x y (f : RoofHom x y) :
> (exists (Hx : x = RNeg) (Hy : y = RNeg), IdNeg = eq_rect _
> (RoofHom
> _) (eq_rect _ (fun x => RoofHom x y) f _ Hx) _ Hy)
> \/ (exists (Hx : x = RZero) (Hy : y = RNeg), ZeroNeg = eq_rect _
> (RoofHom
> \/ (exists (Hx : x = RZero) (Hy : y = RZero), IdZero = eq_rect _
> (RoofHom
> \/ (exists (Hx : x = RZero) (Hy : y = RPos), ZeroPos = eq_rect _
> (RoofHom
> \/ (exists (Hx : x = RPos) (Hy : y = RPos), IdPos = eq_rect _
> (RoofHom
> _) (eq_rect _ (fun x => RoofHom x y) f _ Hx) _ Hy).
> Proof.
> destruct f; [ do 0 right | do 1 right | do 2 right | do 3 right | do 4
> right ]; try left;
> exists eq_refl, eq_refl; reflexivity.
> Qed.
> Proof.
> destruct (RoofHom_inv _ _ f) as
> [ (Hx & Hy & E)
> | [ (Hx & Hy & E)
> | [ (Hx & Hy & E)
> | [ (Hx & Hy & E)
> | (Hx & Hy & E) ] ] ] ]; try discriminate.
> rewrite (UIP_RoofObj _ Hx), (UIP_RoofObj _ Hy) in E.
> simpl in E; auto.
> Qed.
> > De: "John Wiegley"
> > <johnw AT newartisans.com>
> > À:
> > Envoyé: Vendredi 26 Mai 2017 17:42:33
> > Objet: [Coq-Club] Avoiding the use of JMeq_eq
> > I have a simple scenario where I'm representing "objects and arrows" as an
> > inductive type, and another type that references the first one:
> > This gives the structure of a "roof", or Λ, which is used to build span
> > diagrams.
> > A trivial fact I need to prove that this is a category is the following
> > lemma
> > (and others similar in form):
> > However, destruct on 'f' gives me errors about abstracting over variables.
> > "dependent destruction f" works, and completes the proof easily, but
> > incurs
> > the use of JMeq_eq.
> > I'm trying hard to keep this development free of axioms, so I found that
> > the
> > following specialized elimination principle will allow me to avoid
> > JMeq_eq:
> > Definition caseRoofNegNeg (p : RoofHom RNeg RNeg) :
> > forall (P : RoofHom RNeg RNeg -> Type)
> > (PIdNeg : P IdNeg), P p :=
> > match p with
> > | IdNeg => fun _ P => P
> > end.
> > Proof.
> > pattern f.
> > apply caseRoofNegNeg.
> > reflexivity.
> > Qed.
> > Print Assumptions RNeg_RNeg_id.
> > (* Look ma, no axioms. *)
> > Is this the best way of solving the problem? For larger categories there
> > is
> > a
> > lot of boilerplate in providing all these reduction rules, but it's worth
> > it
> > to avoid axioms. Though I thought perhaps, someone knows of a better way?
> > Thank you,
> > John Wiegley GPG fingerprint = 4710 CF98 AF9B 327B B80F
> > http://newartisans.com 60E1 46C4 BD1A 7AC1 4BA2
