- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification
- Date: Thu, 8 Jun 2017 09:52:14 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beta AT mpi-sws.org; spf=Pass smtp.mailfrom=beta AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-phdr: 9a23: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
On Thu, Jun 8, 2017 at 9:42 AM, Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> wrote:
Le 08/06/2017 à 14:38, raffaello.giulietti AT supsi.ch a écrit :
> Hello,
> consider the following z function
> Fixpoint z (n: nat): nat := 0 * z n.
> which Coq accepts with the usual notification "decreasing on 1st argument".
I suppose that during type-checking, Coq performs some kind of reduction
and sees that 0 * z n reduces to 0 (definition of mult) ... hence there
is no recursive sub-call.
On the contrary, the following fails
Fixpoint z (n: nat): nat := z n * 0.
Exactly. The other day, Gil Hur pass me an example of this. The official answer AFAIK is that "Coq is not Strongly Normalizing, but it is Weakly Normalizing. That is ---together with the property of Uniqueness of Normal Forms--- for every reduction scheme either it terminates in THE normal form of the term, or it loops forever. And, for soundness, that's good enough".
- [Coq-Club] Fixpoint "decreasing on 1st argument" notification, raffaello . giulietti, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Gaetan Gilbert, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, raffaello . giulietti, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Beta Ziliani, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Abhishek Anand, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Morrisett, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Dominique Larchey-Wendling, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Pierre-Marie Pédrot, 06/08/2017
- Re: [Coq-Club] Fixpoint "decreasing on 1st argument" notification, Maxime Dénès, 06/08/2017
