coq-club - [Coq-Club] trouble setting up environment to analyse Feit-Thompson proof.
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] trouble setting up environment to analyse Feit-Thompson proof.
  • Date: Wed, 14 Jun 2017 08:29:03 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=kevin.m.buzzard AT gmail.com; spf=Pass smtp.mailfrom=kevin.m.buzzard AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f179.google.com
  • Ironport-phdr: 9a23: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
I am on Ubuntu 14.04. I wanted to take a look at the Coq Feit Thompson
proof. I started with the Ubuntu 14.04 repository of coq (8.4pl5 or
so) and did get as far as compiling the proof with make, but then I
ran into this:
https://mathoverflow.net/a/164998/43076
I felt like this issue shouldn't be ignored, so I decided to start
again and install everything from opam (now giving me Coq 8.6). But
when I do this, "make" in the feit thompson directory gives me
make[1]: Entering directory `/home/buzzard/Encfs/Coq/feit_thompson'
CAMLC -c src/ssrmatching.mli
File "src/ssrmatching.mli", line 76, characters 14-34:
Error: Unbound type constructor glob_constr_and_expr
make[1]: *** [src/ssrmatching.cmi] Error 2
make[1]: Leaving directory `/home/buzzard/Encfs/Coq/feit_thompson'
make: *** [all] Error 2
My understanding of this error is that it's a problem with an early
version of ssreflect not compiling with the later version of coq. I
have installed coq-mathcomp-ssreflect using pam, but now I have to
persuade the Feit-Thompson code to use this more modern version of
ssreflect and I can't see how to change the ssreflect option in the
makefile.
What I am trying to do is to get and IDE up and running where I can
analyse the feit thompson proof files and step through them etc. I'm
finding this tough. Can anyone give me any pointers?
Kevin Buzzard
