- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Case-of-case transformation
- Date: Fri, 16 Jun 2017 17:07:40 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=yoy553 AT mail.usask.ca; spf=None smtp.mailfrom=yoy553 AT mail.usask.ca; spf=None smtp.helo=postmaster AT mail.usask.ca
- Ironport-phdr: 9a23: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
Hi,
I am trying to add a tactic (ccred) to Coq 8.6 so that it syntactically executes case-of-case transformation mentioned in the following paper.
Title: Compiling without continuation
Authors: Luke Maurer, Paul Downen, Zena M. Ariola, and Simon Peyton Jones
Status: Submitted 2016/11/18
URL: https://www.microsoft.com/en-us/research/wp-content/uploads/2016/11/join-points.pdf.
The current implementation
works for simple examples such as the ones used in section 1 and 2 of the above-mentioned paper, but it fails for a slightly complex example: I included both successful (cwc.v) and failure cases (ccred_error.v) in the patch. Testing with variations of
this failure case, I observe De Bruijn index off for some variables (in the case of ccred_error.v the index for one of H0 is off).
I wonder if anyone could point out what is the problem in this implementation, or if someone in the development team can implement case-of-case transformation as a syntactic reduction that even reduces within closures (in
the case of ccred_error.v within the match-_expression_ without eliminating b). I plan to use the reduction as a part of some other automation, and want to avoid elimination argument for simplification.
Following is its main part (a function ccred_reduction which runs for a new brunch in knr to modify the
stack when there is a nested match-_expression_) added to kernel/cClosure.ml:
let rec ccred_reduction info stk m =
match stk with
| ZcaseT (ci_in,t_in,brs_in,env_in) :: stk ->
( match (compact_stack m stk) with
| ZcaseT (ci_out,t_out,brs_out,env_out) :: stk
-> let tctxt_in, tb_in = decompose_lam t_in in
let tctxt_out, tb_out = decompose_lam t_out in
let num_targs_in = List.length tctxt_in in
let num_targs_out = List.length tctxt_out in
let t_new = compose_lam tctxt_in (applistc (lift num_targs_in t_out) [tb_in]) in
let f brs_in_ith = match kind_of_term brs_in_ith with
| Lambda _ -> let ctxt_in,b_in = decompose_lam brs_in_ith in
let num_args_in = List.length ctxt_in in
let brs_out_new = Array.map (lift num_args_in) brs_ou in
compose_lam ctxt_in (mkCase (ci_out, t_out, b_in, brs_out_new))
| _ -> mkCase (ci_out, t_out, brs_in_ith, brs_out)
in
let brs_new = Array.map f brs_in in
let env_new = env_out in
ZcaseT (ci_in, t_new, brs_new, env_new)::stk
| _ -> assert false )
| h1::stk -> h1 :: ccred_reduction info (compact_stack m stk) m
| _ -> assert false (* checked by the branch predicate [is_nested_match_stk] *)
let rec is_nested_match_stk m stk =
match stk with
| [] -> false
| [a] -> false
| ZcaseT _ :: stk ->
| ZcaseT _ :: stk -> true
| _ -> false)
| h :: t -> is_nested_match_stk m t
let rec knr info m stk =
match m.term with
| FFlex _ | FRel _ when !Flags.ccred &&
(is_nested_match_stk m stk) &&
(red_set info.i_flags fCCRED) && !Flags.ccred ->
(m, ccred_reduction info stk m)
Thanks,
Yosuke Y.
- [Coq-Club] Case-of-case transformation, Yamamoto, Yosuke, 06/16/2017
