coq-club - Re: [Coq-Club] "Core" Coq typeclasses
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] "Core" Coq typeclasses
  • Date: Tue, 20 Jun 2017 13:57:11 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f173.google.com
  • Ironport-phdr: 9a23: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
Dear Abhishek,
Thanks for this. For bystanders, the corresponding library is here:
http://math-classes.github.io/
Bas
On Mon, Jun 19, 2017 at 4:35 PM, Abhishek Anand
<abhishek.anand.iitg AT gmail.com>
wrote:
> Typeclasses are merely about inferring some implicit arguments using proof
> search. The underlying modularity mechanism, which is the ability to define
> "existential types" using induction, was ALWAYS there in Coq: typeclasses
> merely cuts down on verbosity because more arguments can now be implicit
> because they can be automatically inferred.
> Relying on proof search often brings predictability concerns. So, guidance
> on taming proof search would be very useful: Chapter 13 of CPDT might be a
> good background for using typeclasses.
> Also, it is good to keep in mind that if typeclass-resolution fails to
> instantiate an implicit argument, some/all of those arguments can be
> provided manually. Often, just providing one such implicit argument gives
> enough clues to the inference engine to infer all of them. I think it is
> important to emphasize that typeclass arguments are just implicit arguments.
> Also, another design decision in typeclasses/records is whether to unbundle.
> The following paper makes a great case for unbundling:
> Spitters, Bas, and Eelis Van Der Weegen. “Type Classes for Mathematics in
> Type Theory.” MSCS 21, no. Special Issue 04 (2011): 795–825.
> doi:10.1017/S0960129511000119.
> http://arxiv.org/pdf/1102.1323v1.pdf
> I think the above paper is missing one argument for unbundling:
> I've seen many libraries that begin by making an interface (say I) that
> bundles ALL the operations (and their correctness properties) they will EVER
> need and then ALL items in the library (say L) are parametrized by over I.
> A problem with this bundled approach is impossible to use ANY part of D if
> you are missing ANY operation (or proof of a logical property of the
> operation) in the interface I, even if parts of D don't actually need that
> operation: I've run into situations where it is impossible to cook up an
> operation that 90% of L doesn't use anyway.
> When using the unbundled approach, one can use Coq's Section mechanism to
> ensure that definitions/proofs only depend on items of the interface they
> actually use, and not on a big bundle.
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
> On Mon, Jun 19, 2017 at 8:45 AM, Pierre Courtieu
> <pierre.courtieu AT gmail.com>
> wrote:
>> Hi
>> my biggest problem with typeclasses is the error messages of the
>> unification engine. It is really hard, even for confirmed users, to figure
>> out from the message why some statement can't be coerced to something
>> typable.
>> Something should be said about typeclasses vs functors/modules but I never
>> came to a clear conclusion about it.
>> P.
>> 2017-06-19 14:00 GMT+02:00 Benjamin C. Pierce
>> <bcpierce AT cis.upenn.edu>:
>>> In preparation for the upcoming DeepSpec summer school, I’m working on
>>> putting together an “even gentler tutorial” on typeclasses in Coq. I’d be
>>> grateful for the community’s advice on what are the most important / most
>>> used typeclasses in the standard libraries (or in widely used contributed
>>> libraries). I plan to use a couple of these as running examples and make
>>> a
>>> list of the rest so that people know they are there.
>>> More generally, I’d love to hear opinions on pragmatic aspects of
>>> typeclasses and how to get newcomers up to speed… E.g.:
>>> What are the most puzzling gotchas that people new to coq’s typeclasses
>>> tend to get stuck on, and what are some good strategies for getting
>>> un-puzzled?
>>> What advice should be given to new typeclass users to avoid getting
>>> themselves in trouble? What are the tradeoffs between typeclasses and
>>> other
>>> modularity mechanisms in Coq.
>>> Thanks!
>>> - Benjamin
