- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Defining complex recursive functions
- Date: Wed, 28 Jun 2017 20:07:25 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=anton.a.trunov AT gmail.com; spf=Pass smtp.mailfrom=anton.a.trunov AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f42.google.com
- Ironport-phdr: 9a23:I9n/Gh1CG5srlyQusmDT+DRfVm0co7zxezQtwd8Zse0fKfad9pjvdHbS+e9qxAeQG96KtLQc06L/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFcVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q89pDXYQhEniaxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4KdxUBLmiDsIOTE2/2/KhMJwgrxVrxCiqRJ42IPUfJiVNP9icqPdYd8XR2xMVdtRWSxbBYO8apMCAvYHPeZEqIn9oUYFowWkBQmxAuPvzSFIjWLx0KIg1eQhDQbG3Ao6E90UqnjUsM/1NLoUUeCy0qnF1jrDb/ZM1jf87IjEaAwuofaJXb9pd8fa1EchFwTAjlqKqIzlOSuY1uULs2ia8+psT+yui2A/pwF3uDev2t0gio3Vho8T11vK9j15zZ4rKdGkTEN3e92pHZtKuy2EKod7QtkuTm52tCoi17ELvZ62cDIXxJkj2hLTceGLfoeJ7x75SeqcIDF1j29/dr2lnRa9602gx/X8Vsaq1FZKqTJIktzWuXAM0xzf88yHSvVh8ku41zaC2B7f5vtLIUAzkqrbJJohzaAqmpUPtkTDGzf6mETwjKCIakUp4vak5/jjb7n8pZKRN5V4hh/jPqkugMCyDvo0PhALX2eB+OS80LPj/Vf+QLVPlvA5iK/ZsIzdJcQdvKK2GRVZ0po56xaiCTem18oYkGIILFJAYh2HjozpN0vSL/D/CPezm06snytzx/DaIr3hBY3AIWTEkLf4ZLpy90pcyBcowt1E/JJVCrQBIOrpVUPrtdzYCAU5Mw2uzOr9BtV9zNBWZWXaCaiAdajWrFWg5+Q1IuDKapVGliz6Lq0M4eLpizcFg0IberfhiZIRdHe+WP0gP1+EZ33yqtgEGGYO+AE5Sbq52xW5TTdPaiPqDOoH7TYhBdf+AA==
Hi Christian,
Actually, [Program] provides “*_eq” lemmas, but apparently you have to use
[match … with]:
Program Fixpoint bar (G : graph) {measure (size G)} : nat :=
match (property G) with true => bar (dec1 G) | false => 4 end.
Next Obligation.
now apply dec1_lt.
Defined.
From the manual (§24.1.1) "the if construct is not treated specially by
PROGRAM so boolean tests in the code are not automatically reflected in the
obligations”.
best regards,
Anton Trunov
> On 28 Jun 2017, at 19:23, Christian Doczkal
> <christian.doczkal AT ens-lyon.fr>
> wrote:
> Hi,
> Thanks for the replies, I had tried something along these lines as well,
> albeit not too hard. Your solution (and that of Gaetan) however require
> quite a bit of dependent programming.
> Further, even on this simple example the definition generated this way
> does not look like I want to prove anything about it and, as far as I
> can tell, Program does not provide anything corresponding to Function's
> "*_eq" lemmas. Fully specifying he behavior using sigma-tyoes is also
> not realistic in my case.
> I guess that means I'll use bounded recursion.
> Cheers,
> Christian
> On 28/06/17 14:09, Frédéric Besson wrote:
>> Hi Christian,
>> I am far from having a definite opinion.
>> Yet, you can guide Program Fixpoint to get stronger proof obligations.
>> For instance, here is what you could do:
>> Require Import Program.Tactics.
>> Require Import Program.Wf.
>> Require Import List.
>> Variable graph : Type.
>> Variable size : graph -> nat.
>> Variable propertyP : graph -> bool.
>> Variable decompose : forall (g:graph),
>> list {g':graph| size g' < size g}.
>> Program Fixpoint foo' (G : graph) {measure (size G)} : nat :=
>> if propertyP G
>> then fold_right (fun H m => Nat.max H m) 0 (map (fun gp => foo'
>> (proj1_sig gp)) (decompose G))
>> else 4.
>> Next Obligation.
>> apply measure_wf.
>> apply PeanoNat.Nat.lt_wf_0.
>> Defined.
>> PS: I also often lean towards bounded recursion.
>> Frédéric
>> On Tue, 2017-06-27 at 14:51 +0200, Christian Doczkal wrote:
>>> Hello,
>>> I need to define a rather complicated non-structurally recursive
>>> function and I would like to gather some input as to which way i
>>> should
>>> proceed.
>>> I know of the following facilities/techniques to define non-
>>> structurally
>>> recursive functions:
>>> - Program Fixpoint
>>> - The Function command
>>> - Using Coq.Init.Wf.Fix
>>> - Using an extra Argument of type nat bounding the recursion depth
>>> I will need variable-width recursion (i.e., mapping the function over
>>> lists of smaller arguments). This is not supported by Function.
>>> Indeed
>>> the following fails as expected (self contained file attached):
>>> Fail Function foo (G : graph) {measure size G} : nat :=
>>> if property G
>>> then fold_right (fun H m => Nat.max (foo H) m) 0 (decompose G)
>>> else 4.
>>> Program fares little better:
>>> Program Fixpoint foo (G : graph) {measure (size G)} : nat :=
>>> if propertyP G
>>> else 4.
>>> Here I'm asked to prove "size H < size G" without knowing that H is
>>> from
>>> "decompose G". Trying to map before folding, I don't even get
>>> obligations:
>>> Fail Program Fixpoint foo' (G : graph) {measure (size G)} : nat :=
>>> if propertyP G
>>> then fold_right (fun H m => Nat.max H m) 0 (map foo' (decompose G))
>>> else 4.
>>> I guess that meas that for Program all occurrences of the recursive
>>> function must also be fully applied? Is there a trick to use Program
>>> for
>>> variable-width recursion?
>>> Otherwise I guess I'll have to use either use Wf.Fix (providing a
>>> variant of map that threads through the size bound) or use bounded
>>> recursion with an extra argument.
>>> Are there any other facilities/techniques I should try or does anyone
>>> have experience with this kind of function definition? I'm leaning
>>> towards bounded recursion, since this seems to require minimal use of
>>> dependent types and should yield the smallest/cleanest definition
>>> (possibly at the cost a larger proof burden, i.e, to prove the
>>> fixpoint
>>> equation and the functional induction principle).
>>> I'd be thankful for any type of input.
>>> Regards,
>>> Christian
>>> PS. Is there a way to Abort a Program Definition/Fixpoint etc. Using
>>> "Abort." on an obligation merely seems to shelf this obligation.
- [Coq-Club] Defining complex recursive functions, Christian Doczkal, 06/27/2017
- Re: [Coq-Club] Defining complex recursive functions, Gaetan Gilbert, 06/28/2017
- Re: [Coq-Club] Defining complex recursive functions, Frédéric Besson, 06/28/2017
- Re: [Coq-Club] Defining complex recursive functions, Christian Doczkal, 06/28/2017
- Re: [Coq-Club] Defining complex recursive functions, Anton Trunov, 06/28/2017
