- To: coq-club AT inria.fr
- Subject: [Coq-Club] ProofObject and Definitions
- Date: Sun, 16 Jul 2017 06:55:53 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=beviguier AT gmail.com; spf=Pass smtp.mailfrom=beviguier AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f182.google.com
- Ironport-phdr: 9a23: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
Dear Coq-club
My problem is as follow. When I do the Print answer I get a really big ProofObject (nothing wrong with that) but when I want to use that proof object to directly feed it into another definition, I get the following error: Syntax error: [constr:lconstr] expected after ':' (in [constr:open_binders]). This is due to in the line that some "..." that appeared. A few lines later I also have this chunk of code : (fun e : ℕ => match ... with | ... False | ... False | ... False | ... False | ... False | ... False | ... False | ... True | ... False end) I 16%nat Ha'7 Which I'm pretty sure won't be parsed (this does not look like correct Galina). How can I make sure that the proof term that I get will be
correct (The proof term is 20 000 character long) ? ---------------------------------------------------------------------------------------------------------------------------------------- The motivation of this approach is as follow : All the 'apply/eapply', 'repeat', 'match' are building the proof
term. But finding the right lemma with eauto etc is long and slow. Thus what about using the proofobject directly as a definition
and skip the whole "building proof via tactial" step -- Kind regards, Benoît Viguier Software Engineer - PhD Student | Cryptography & Formal Methods Radboud University | Mercator 1, room 03.17, Toernooiveld 212 6525 EC Nijmegen, the Netherlands | www.viguier.nl -------------------------------------------------------------------------- This message (and any attachments) is intended solely for the addressee(s) and may contain confidential information. If you are not the addressee, do not copy this message (and any attachments), forward or share this message with third parties. You are requested to notify the sender immediately and delete this message. |
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] ProofObject and Definitions, Benoît Viguier, 07/16/2017
- Re: [Coq-Club] ProofObject and Definitions, Pierre Courtieu, 07/16/2017
