- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Gallina evaluator that plows thru stuck proofs?
- Date: Thu, 10 Aug 2017 10:11:04 +0200
On 09/08/2017 21:46, Abhishek Anand wrote:
> I am wondering whether someone has written a more lenient version of
> vm_compute (or native_compute) that plows through stuck proofs,
> similar to the way extracting to OCaml and then evaluating would.
> I understand that such an evaluator may in general diverge and produce
> results that disagree
> with Coq's reduction semantics. However, it seems possible to have the
> evaluator
> agree with the result of evaluating the OCaml extract, at least for
> programs of "simple" non-propositional types such as nat.
Some times ago I did work on a version of vm_compute that skips proofs
(rather than plows through them). So it is not quite the same as what
you expect. In particular, if my version gets a reduced term at the end,
then it is necessarily the reduced term (so the system stays
consistent), contrarily to what an extraction-based mechanism would provide.
https://github.com/silene/coq/tree/VMaccu
Unfortunately, more pressing matters happened and I never got to
complete the work. It is still on my todo list and I hope to free some
time during Fall. As far as I remember, the back-end was complete. There
were three small pieces missing from the middle-end:
1. Mark some opaque symbols as absorbing. While the performance gain is
already noticeable as it stands, it is nowhere near what one expects
until this part is implemented.
2. Add a compile-time optimization to mark match constructs with only
absorbing branches as absorbing. This is helpful for not wasting time
when evaluating things like proofs by contradiction.
3. Be a bit more user- and ltac-friendly when an absorbing element
remains after a reduction and thus causes vm_compute to abort (what you
call a "disagreement").
Best regards,
Guillaume
- [Coq-Club] Gallina evaluator that plows thru stuck proofs?, Abhishek Anand, 08/09/2017
- Re: [Coq-Club] Gallina evaluator that plows thru stuck proofs?, Guillaume Melquiond, 08/10/2017
