coq-club - Re: [Coq-Club] How to add file locations for Require Import? (CoqIde)
  • From: Gaetan Gilbert <gaetan.gilbert AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to add file locations for Require Import? (CoqIde)
  • Date: Sun, 20 Aug 2017 10:50:36 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT ens-lyon.fr; spf=Neutral smtp.mailfrom=gaetan.gilbert AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:p8dNohC7bd6pLEUhn+qQUyQJP3N1i/DPJgcQr6AfoPdwSP39o8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERLmcAFxO+7dG4jIjs3x2frh1YfUZlBnjTehaLU6AxSypwjLqoFCjoJvNq83jBTIpnFFYfh+yGVzYFaCmBC66N3mr80ryDhZp/90r50Iaq79ZaltFbE=
A Coq source file foo.v contains some text like "Definition foo : bar := baz.". It must be compiled into a file foo.vo (which humans are incapable of reading) before you can Require Import foo. Essentially Coq runs itself on the file and outputs the compressed results to the vo.
With a single file foo.v you can simply run the program coqc on it to compile it, but if you have multiple files which Require each other there is an order in which you have to compile them so that each vo is available before a file which Requires it is compiled. "make" is a program which runs compilation commands in the right order depending on information stored in a Makefile (you will notice that one came with the cpdt files) (make is not Coq specific).
Finally when the cpdt book says
> Be sure to run the Coq binary coqtop with the command-line argument -R DIR/src Cpdt.
this also applies to running coqide.
Gaëtan Gilbert
On 20/08/2017 09:06, Manny Romero wrote:
Thank you for your help.
I had read the section you describe. It looked--and it still looks--like it is mostly about people using Coq in Emacs. I do not have Emacs; I have been using CoqIde. There may be a part of the section you cite that is relevant for my purposes; but again, I am much too unfamiliar with computers to know what that would be and how to use it. For example, I don't know what "make" is yet, so I can't currently make sense of an abstract instruction to use it (if indeed that part is applicable to CoqIde). More specific advice, beyond what I had already seen e.g. in the textbook, was exactly what I was hoping to get help on.
*Sent:* Sunday, August 20, 2017 at 2:35 AM
<karen.sarkisyan AT gmail.com>
*To:*
*Subject:* Re: [Coq-Club] How to add file locations for Require Import? (CoqIde)
You'll need to read "1.6.3 Installation and Emacs Set-Up" from Chapter 1 (Introduction) in Cpdt book and do all the steps beyond unzipping.
There is an easy way to experiment with code in your browser as well.
At https://x80.org/collacoq/ you need to click on Packages (right and down at the page)
to load required packages, like cpdt, cor-arith, coq-base...
Then, to import all you need, just do:
From Coq Require Import Bool.Bool Arith.Arith Lists.List.
From Cpdt Require Import CpdtTactics.
Set Implicit Arguments.
Set Asymmetric Patterns.
Hope this is useful.
Best,
Karen Sargsyan
On Sun, Aug 20, 2017 at 1:43 PM, Manny Romero <mannyromero AT mail.com <mailto:mannyromero AT mail.com>> wrote:
Hello! Apologies if this isn't the appropriate mailing list; I
couldn't find a Coq beginners' list anywhere.
I am someone who is ignorant of the most basic aspects of
computers who is getting started with Coq. I have installed the
CoqIde 8.4pl4 on Linux Mint 18 and used it successfully with some
simple tutorials.
Now, however, I am trying to use the textbook **Adam Chlipala** (
http://adam.chlipala.net/cpdt/ ); and, as explained at the
beginning of Chapter 2, it requires me to "Require Import" various
files to follow along with the texts and do the exercises.
Specifically, I must:
Require Import Bool Arith List Cpdt.CpdtTactics.
Cpdt.CpdtTactics is among the files available for download on the
Chlipala website. I downloaded all the files and "unzipped" them
into a subfolder I made within my folder
/home/mannyromero/Downloads; but that is not among the locations I
see when I enter "Print LoadPath" into the CoqIde, which I assume
is why I get a message "Error: Cannot find library
Cpdt.CpdtTactics in loadpath" when I try to Require Import as above.
What do I do to add the location of the Cpdt.CpdtTactics file to
the CoqIde's list somehow so that I can Require Import it and
proceed with the textbook exercises?
Or, if this is off topic or inappropriate, apologies and can
someone direct me to a better community to ask this question?
