coq-club - [Coq-Club] Nominal reasoning in Coq
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Nominal reasoning in Coq
  • Date: Wed, 23 Aug 2017 11:04:42 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-vk0-f65.google.com
  • Ironport-phdr: 9a23:KkwcwhwoanW4I4bXCy+O+j09IxM/srCxBDY+r6Qd0uwXIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi56idXERHiPyJ0IP70E8jclZeZzee3rqHaZwRBzAC8Z7x/Nl3isR/QsMYbm6NpMeAuwwDJo31HZ+NQg25kOATAzF7H+s6s8cs7oGxrsPU7+psYXA==
Hi all,
I'm wondering if something like nominal Isabelle exists in Coq. I've found an extended abstract that discusses this, but I am yet to find follow-up work. I know there is a documented need for it, so I'm wondering if anyone further work exists, and especially if there are any tools that people use, since I know that Nominal Isabelle is very popular.
If there is no analogue, I'm curious if anyone knows whether this is fundamental to the difference in logics between Coq and Isabelle, or whether this is "just" a matter of someone building an analogous effective tool in Coq itself.
Thanks!
Talia
