- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Instantiate a parameter of a module type with an inductive type
- Date: Tue, 12 Sep 2017 13:50:40 +0200
- Organization: Inria
Hi,
To avoid this error message, your inductive type should not be named t
but, say, _t.
Then, you can define t as _t.
Definition t := _t.
This error message has been there for ages. Isn't there a FAQ
explaining the workaround ?
Best,
Frédéric
On Mon, 2017-09-11 at 14:36 -0500, Helmut Brandl wrote:
> Dear list,
> I have the following module types
> Module Type MONAD.
> Parameter t: Type -> Type.
> Parameter apply: forall A B:Type, (A->B) -> t A -> t B.
> Parameter map: forall A B:Type, (A->B) -> t A -> t B.
> Parameter bind: forall A B:Type, t A -> (A -> t B) -> t B.
> End MONAD.
> Module Type MONAD0.
> Parameter make: forall A:Type, A -> t A.
> End MONAD0.
> and the module functor
> Module Monad_of (M:MONAD0).
> Definition t := M.t.
> Definition bind := M.bind.
> Definition make := M.make.
> Arguments bind {A} {B} _ _.
> Arguments make {A} _.
> Definition map {A B:Type} (f:A->B) (m:t A): t B :=
> bind m (fun a => make (f a)).
> Definition apply {A B:Type} (f: t (A->B)) (m: t A): t B :=
> bind f (fun f0 => map f0 m).
> End Monad_of.
> I wanted to use the following module as a module argument for the
> previous functor
> Module Option.
> Inductive t (A:Type) :=
> | None: t A
> | Some: A -> t A.
> Check t.
> Arguments None {A}.
> Arguments Some {A} _.
> Definition make {A:Type} (a:A): t A :=
> Some a.
> Definition bind {A:Type} (m:t A) (f:A->t A): t A :=
> match m with
> | None =>
> None
> | Some v =>
> f v
> end.
> Check make.
> End Option.
> Module Option1 := Monad_of(Option).
> With the last line the compiler complains with the message "The
> kernel does not recognize yet that a parameter can be instantiated by
> an inductive type. Hint: you can rename the inductive type and give a
> definition to map the old name to the new name."
> Can anybody help me to understand this error message and give me a
> hint on how to fix this problem?
> Thanks
> Helmut
- [Coq-Club] Instantiate a parameter of a module type with an inductive type, Helmut Brandl, 09/11/2017
- Re: [Coq-Club] Instantiate a parameter of a module type with an inductive type, Frédéric Besson, 09/12/2017
