- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem with dependent match statement
- Date: Fri, 15 Sep 2017 12:10:05 +0200
- Organization: LORIA
Dear Michael,
It seems to me that Fin n is the type of numbers (nat) below n,
hence the equivalence:
Fin n ~=~ { i : nat | i < n }.
Hence Fin 0 has to be an empty type. Fin n is defined
in the Coq Vectors.Fin module of the Standard Library.
Best,
D.
Le 15/09/2017 à 12:05, Soegtrop, Michael a écrit :
> Dear Jeff,
> I wonder what is the advantage of using a definition of Fin n which is
> equivalent to False for n=0 in connection with Vectors which exist for n=0.
> What bad things would happen if Fin 0 would be defined and equivalent to a
> 0-tuple of unit rather than something which doesn't exist at all? Is the
> fact that Fin 0 -> False used for ex falso quod libet proofs in some
> places? Since the 0 length constructor of vectors is trivial I don't see
> many applications for this. So unless you really need ex falso quod libet
> proofs using Fin 0 somewhere, I have doubts that this is the most efficient
> (in terms of human time to get things done) way of setting up things.
> Best regards,
> Michael
> Intel Deutschland GmbH
> Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
> Tel: +49 89 99 8853-0, www.intel.de
> Managing Directors: Christin Eisenschmid, Christian Lamprechter
> Chairperson of the Supervisory Board: Nicole Lau
> Registered Office: Munich
> Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] Problem with dependent match statement, Terrell, Jeffrey, 09/15/2017
- RE: [Coq-Club] Problem with dependent match statement, Soegtrop, Michael, 09/15/2017
- Re: [Coq-Club] Problem with dependent match statement, Jan-Oliver Kaiser, 09/15/2017
- Re: [Coq-Club] Problem with dependent match statement, Dominique Larchey-Wendling, 09/15/2017
- Re: [Coq-Club] Problem with dependent match statement, Terrell, Jeffrey, 09/15/2017
- Re: [Coq-Club] Problem with dependent match statement, Terrell, Jeffrey, 09/16/2017
- RE: [Coq-Club] Problem with dependent match statement, Soegtrop, Michael, 09/18/2017
- Re: [Coq-Club] Problem with dependent match statement, Terrell, Jeffrey, 09/21/2017
- RE: [Coq-Club] Problem with dependent match statement, Soegtrop, Michael, 09/22/2017
