- To: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Adding ML tactic plugins
- Date: Sun, 1 Oct 2017 22:22:20 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM02-BL2-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:m87mjx/2wiDRlP9uRHKM819IXTAuvvDOBiVQ1KB+1e8cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV91a19Hs5Hgj1fV5+If2wEYrPhey20fqz8tvdeVMbqiC6ZOZRIROwoBnR/vMRjMM2Kas3xgHOr1NIfPhTzGJsY1mUmkCvtY+L4Jd//nEI6Loa/MlaXPCicg==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Sent: Friday, September 29, 2017 12:00 PM
To: Coq-Club
Subject: [Coq-Club] Adding ML tactic plugins
TACTIC EXTEND AR2
| [ "arewrite" ] -> [ arewrite ]
END;;
(* PrintAST command
The depth specifies the depth at which to unroll nested type definitions *)
VERNAC COMMAND EXTEND AR
| [ "printAST" constr(def) ] -> [ print_ast 0 def ]
| [ "printExp" constr(def) ] -> [ print_exp 0 def ]
| [ "printAST" constr(def) "with" "depth" integer(depth)] -> [ print_ast depth def ]
END;;
Kenneths-MBP:plugin kendroe$ coqtop
Welcome to Coq 8.5pl2 (July 2017)
Coq < Require Export AdvancedRewrite.advancedRewrite.
[Loading ML file AdvancedRewritePlugin.cmxs ... done]
Coq < printAST (1+2).
(App (Definition Coq.Init.Nat.add (Fix (Functions ((Name add) 0 (Prod (Name n) (Name nat) (Prod (Name m) (Name nat) (Name nat))) (Lambda (Name n) (Name nat) (Lambda (Name m) (Name nat) (Case 0 (Lambda (Name n) (Name nat) (Name nat)) (CaseMatch (Name n)) (CaseBranches (Name m) (Lambda (Name p) (Name nat) (App (Construct (Name nat) 2) (App (Name add) (Name p) (Name m)))))))))) 0)) (App (Construct (Name nat) 2) (Construct (Name nat) 1)) (App (Construct (Name nat) 2) (App (Construct (Name nat) 2) (Construct (Name nat) 1))))
Coq < Theorem x: 1+2=3.
1 subgoal
1 + 2 = 3
x < arewrite.
Toplevel input, characters 0-8:
> arewrite.
Error: The reference arewrite was not found in the current environment.
x <
- Re: [Coq-Club] Adding ML tactic plugins, Kenneth Roe, 10/02/2017
- Re: [Coq-Club] Adding ML tactic plugins, Emilio Jesús Gallego Arias, 10/02/2017
