- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Separation of interface and implementation
- Date: Thu, 12 Oct 2017 18:45:35 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f53.google.com
- Ironport-phdr: 9a23:S+Y6pReHs/RvQBeVHHA+7AVSlGMj4u6mDksu8pMizoh2WeGdxc2zYx7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpRZbIBj0NBJ0K+LpAcaSyp3vj6Hhs6HUNi5PnXKWZa54ZEG9qhyUvc0Li6NjLLwww13HuC0bVf5RwDZQJF+JhRu0zcCt5oJi/jkY7+og+tRaXOPxeLkiUb1VERwpNmk04IvgshyVHljH3WcVTmhDykkAOAPC9hyvG86p6iY=
Hi,
First note people generally use "Module Foo <: Bar", which checks the
type of Foo against Bar but leaves everything in Foo visible.
However the duplication problem remains and here is how I would do
(look at the Include directive):
Module TEST_F.
Definition f : nat -> nat := fun n => n.
End TEST_F.
Module Type TEST_SIG.
Include TEST_F.
Parameter g : nat -> nat.
Axiom t : True.
End TEST_SIG.
Module TEST : TEST_SIG.
Include TEST_F.
Definition g_helper : nat -> nat := S.
Definition g : nat -> nat := g_helper.
Lemma helper_lemma : True.
Proof. exact I. Qed.
Theorem t : True.
Proof. apply helper_lemma. Qed.
End TEST.
BUT your example is oversimplified: TEST_F is a module but in general
it is a module type, and then Include a module Type inside a module
does not work. Suppose for instance that your module type is like
this:
Variable A:Type.
Definition f : A -> A := fun n => n. (* Notice how f depends on a
*variable* *)
Axiom t : True.
End TEST_SIG.
The solution I know for this is a bit heavy.
1) Define a minimal module type MINMT which contains every variable
needed by visible definitions.
2) define the common part of both module and module type as a functor
on a MINMT.
3) define module types as a functor on MINMT and including ("Include")
this common part. Everything takes INMT as a parameter.
4) Instantiate the module and also include MINMT in it.
(* Minimal module type to write visible definitions in main module
type. This will be taken as parameter by all module types AND modules,
that is the main point. *)
Module TEST_SIG_SIG.
Variable A: Type.
End TEST_SIG_SIG.
(* Visible definitions are stored in a functor, this is the shared
part (included in both main module type and main module. *)
Module Type TEST_F(TSS:TEST_SIG_SIG).
Include TSS.
Definition f : TSS.A -> TSS.A := fun n => n.
End TEST_F.
(* The main module type *)
Module Type TEST_SIG(TSS:TEST_SIG_SIG).
Include TEST_F(TSS).
Parameter g : nat -> TSS.A.
Axiom t : True.
End TEST_SIG.
(* Instantiating the parameter module*)
Module TEST_nat.
Definition A := nat.
End TEST_nat.
(* Instantiating the main module type *)
Module TEST : TEST_SIG(TEST_nat).
Include TEST_F(TEST_nat).
Theorem t : True.
End TEST.
Hope this helps.
Pierre
2017-10-12 16:50 GMT+02:00 Anders Lundstedt
<anders AT anderslundstedt.se>:
> Hi,
> I am doing some theorem proving in Coq. My development is split over
> multiple files. I would like each file to first list all its
> definitions and theorems. Some definitions should be transparent: they
> should be listed in full here. Theorems and some definitions should be
> opaque: only their name and type should be shown. The proof of
> theorems and implementation of opaque definitions should come later.
> Any helper lemmas and functions used here should not be exposed at
> all. So, something like this:
> (* exposing the definition of f *)
> (* g should be opaque, its definition is not shown here *)
> (* opaque theorems *)
> Axiom t : True.
> (* implementations *)
> (* helper lemma, should not be exposed at all *)
> Theorem t : True.
> (* helper function, should not be exposed at all *)
> Questions:
> (1) What is the best way to accomplish this in Coq?
> (2) Is this a good idea? If not, what should I do instead?
> Regarding (1): I can achieve this using modules, but I have not found
> a way to avoid having to define all transparent definitions
> twice—first in the module type and then in the module. (If I also have
> notations I want to expose it seems even worse: I have to define them
> in the module type and in the module and then outside the module.)
> Here is how I have achieved the above example using modules:
> Axiom t : True.
> End TEST_SIG.
> Theorem t : True.
> End TEST.
> Anders
- [Coq-Club] Separation of interface and implementation, Anders Lundstedt, 10/12/2017
- Re: [Coq-Club] Separation of interface and implementation, Pierre Courtieu, 10/12/2017
- Re: [Coq-Club] Separation of interface and implementation, Ralf Jung, 10/12/2017
