coq-club - [Coq-Club] Axiomatize ocaml integers
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Axiomatize ocaml integers
  • Date: Thu, 12 Oct 2017 17:36:41 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=helmut.brandl AT gmx.net; spf=Pass smtp.mailfrom=helmut.brandl AT gmx.net; spf=None smtp.helo=postmaster AT mout.gmx.net
  • Ironport-phdr: 9a23:rlhsBxacdbKqj+4iqD4kWBv/LSx+4OfEezUN459isYplN5qZpsmybnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUD0MhMwLeDoEKbTid623qa84c79eQJN0RqwZbZvMF2ctwzXus1e1YtvLqMs1l3DuHJOd+B+ymZ4Y1Seg0CvtY+L4Jd//nEI6Loa/MlaXPCicg==
Hi,
I want to use coq to extract code to ocaml and use ocaml ints.
I ocaml I can write the following recursive function which certainly terminates:
  let rec some_function (i:int) (a:'a): 'a =
    if i = min_int then
      some_expression
    else
      some_function (i-1) (some_g a)
I want to write a function in coq which extracts to such an ocaml function. I have tried some axiomatizations, but I have not yet achieved the desired result.
Parameter min_int: int.
Parameter max_int: int.
Parameter int_eqb: int -> int -> bool.
Parameter int_leb: int -> int -> bool.
Parameter int_ltb: int -> int -> bool.
Parameter int_plus:  int -> int -> int.
Parameter int_minus: int -> int -> int.
.. (* some more parameters to have le, lt, .. and the corresponding axioms *)
Inductive all_ints: int -> Prop :=
  All_ints_base: all_ints min_int
| All_ints_next: forall i, all_ints i -> i <> max_int -> all_ints (i+1).
Axiom all_ints_in_all_ints: forall i:int, all_ints i.
I wanted to use the the inductive set ‘all_ints’ to control termination and e.g. write a recursive function like the following.
Fixpoint some_function (n:int) (p:all_ints n) {struct p}: int.
Proof.
  refine (
  match n =? min_int with
    true => 0
  | false => some_function (n-1) _ + 1
  end).
Defined.
But I could not find a way to construct the missing _expression_ such that coq accepts it as a decreasing argument. There must be a possibility since the above axiom states that all ints are in an inductively definded set. I assume that some dependent pattern matching can do the job. But I have not yet enough expert knowledge to find this _expression_.
Can anybody help me or give me a hint on how to do this?
Thanks in advance.
Helmut
