coq-club - Re: [Coq-Club] Constructing a match expression inside an ml tactic
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Constructing a match expression inside an ml tactic
  • Date: Fri, 13 Oct 2017 14:07:21 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=enrico.tassi AT inria.fr; spf=None smtp.mailfrom=gares AT fettunta.org; spf=None smtp.helo=postmaster AT fettunta.org
  • Ironport-phdr: 9a23:fRlrlRYhAXigSlgNz5oRPob/LSx+4OfEezUN459isYplN5qZpsm9bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUD0MhMwLeDoEKbTid623qa84c79eQJN0Re7e7J5K12KpB7Kt4FCjI14K602jAfAuWBJU+VQ32JhY1yJyUWvrvys9YJupnwD88kq8NRNBP33
On Mon, Oct 09, 2017 at 01:42:54AM +0000, Kenneth Roe wrote:
> let ci = make_case_info Global.env ind RegularStyle in
> mkCase (ci, tterm, eterm, Array.of_list terms)
> The "ci" field seems to contain information I need to pull from the
> global environment. I was able to figure out the first and third
> parameters by looking at pieces of code in Coq. However, I'm not able
> to figure out what to do with the "ind" field. What do I fill in for
> ind?
It is an inductive type. This is how I do:
https://github.com/LPCIC/coq-elpi/blob/master/src/coq_elpi_HOAS.ml#L644
In that code I know rt is a spine of lambdas ending with an applied
inductive type. This is also relevant
https://github.com/coq/coq/blob/master/kernel/names.mli#L390
My 2 cents,
Enrico Tassi
