- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq on Android?
- Date: Wed, 18 Oct 2017 22:03:26 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f169.google.com
- Ironport-phdr: 9a23:52wKnh2e4/yaku3qsmDT+DRfVm0co7zxezQtwd8ZsesRIvad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jkLXx77KAA9cu/yA8vZi9m9/+G04ZzaJQtS0mmTe7R3eTy8rQTKtsQVyaJkI6A9gk/AqHtJYORbxiVhI1uVk1D959u/1JFm+iVU/fkm8pgTAu3BY60kQOkAX3wdOGcv6ZizuA==
Yes, I would switch between the 3 buffers.
It would help to make the switching easy in the one-buffer mode.
For example, if the key bound to "company-coq-proof-goto-point" (C-c RET by default) is pressed in a non-code buffer, the code buffer should be switched to.
Also, when that key is pressed in the code buffer, inside a proof or immediately after a query, the proof or the query buffer may be switched to accordingly.
An android user can then assign a convenient key, perhaps even a hardware button (e.g. power button) to trigger "company-coq-proof-goto-point" .
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Wed, Oct 18, 2017 at 3:51 AM, Pierre Courtieu <pierre.courtieu AT gmail.com> wrote:
Thanks for details,
How would you see the state of your goal in one-buffer mode? Would you
switch between the three buffers?
Pierre
- [Coq-Club] Coq on Android?, Nicolas Pelletier, 10/16/2017
- Re: [Coq-Club] Coq on Android?, Abhishek Anand, 10/16/2017
- Message not available
- Re: [Coq-Club] Coq on Android?, Kyle Stemen, 10/16/2017
- Re: [Coq-Club] Coq on Android?, Nicolas Pelletier, 10/17/2017
- Re: [Coq-Club] Coq on Android?, Daniel Galvez, 10/17/2017
- Re: [Coq-Club] Coq on Android?, Pierre Courtieu, 10/17/2017
- Re: [Coq-Club] Coq on Android?, Vadim Zaliva, 10/17/2017
- Re: [Coq-Club] Coq on Android?, Abhishek Anand, 10/18/2017
- Re: [Coq-Club] Coq on Android?, Pierre Courtieu, 10/18/2017
- Re: [Coq-Club] Coq on Android?, Abhishek Anand, 10/19/2017
- Re: [Coq-Club] Coq on Android?, Nicolas Pelletier, 10/18/2017
- Re: [Coq-Club] Coq on Android?, Laurent Thery, 10/18/2017
- Re: [Coq-Club] Coq on Android?, Kyle Stemen, 10/25/2017
- Re: [Coq-Club] Coq on Android?, Nicolas Pelletier, 10/26/2017
