coq-club - [Coq-Club] Issue with Hint Resolve and typeclasses eauto
  • From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Issue with Hint Resolve and typeclasses eauto
  • Date: Thu, 26 Oct 2017 14:14:19 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=armael.gueneau AT ens-lyon.fr; spf=Neutral smtp.mailfrom=armael.gueneau AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:AM7czR/lB2hhaf9uRHKM819IXTAuvvDOBiVQ1KB+1O0cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47ISVLemlqXpX5PQ1SsfTZyc+/yA8vZi9m9/+G04ZzaJQtS1xSnZrYnBQ+zpIbVgeYLAI1vI7t5nhLTp3JFf6JZ2G5uKFuOtxv6/YK07ZlltSpK7aFyv/VcWLn3KvxrBYdTCy4rZj1s6Q==
Dear coq-club,
I am trying to use the "typeclasses eauto" tactic in combination with
custom hint bases, and I am observing confusing behavior with respect to
hints added using "Hint Resolve".
The snippet below (also attached) illustrates the issue.
Essentially, in many cases, hints registered using "Hint Resolve" seem
to not be picked up. However, adding them instead using "Hint Extern"
and a pattern that exactly matches the conclusion of the lemma makes
them work...
Of course I could turn all my "Hint Resolve" into "Hint Extern" (that
would be a bit tedious), but I'm wondering if there's a reason for this
behavior of "typeclasses eauto". Maybe this is the result of some
subtlety of the tactic I'm not aware of?
Cheers,
Armaël
Record type : Type := Pack { sort : Type }.
Coercion sort : type >-> Sortclass.
Definition nat_packed := Pack nat.
Parameter R : forall (A : Type), (A -> nat) -> (A -> nat) -> Prop.
Hypothesis R_refl : forall (A : Type) f, R A f f.
Hint Resolve R_refl : myhints.
Goal forall f, R nat_packed f f.
intro. simple apply R_refl.
Qed. (* ok *)
intro. typeclasses eauto with myhints.
Qed. (* ok *)
Goal R nat_packed (fun x => x) (fun x => x).
Qed. (* ok *)
Fail typeclasses eauto with myhints.
Abort. (* ?? *)
Print HintDb myhints.
(* This seems to replicate the exact pattern that can be found for
[R_refl] in [myhints]... *)
Hint Extern 0 (R _ ?f ?f) => simple apply R_refl : myhints2.
typeclasses eauto with myhints2.
Qed. (* ??? *)
Qed. (* ok *)
Qed. (* ok *)
Qed. (* ok *)
Abort. (* ?? *)
(* This seems to replicate the exact pattern that can be found for [R_refl] in
   [myhints]... *)
Qed. (* ??? *)
  • [Coq-Club] Issue with Hint Resolve and typeclasses eauto, Armaël Guéneau, 10/26/2017
