- From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
- To: mail AT maximedenes.fr
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] plugin load issue
- Date: Fri, 27 Oct 2017 07:17:41 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-2.u-ga.fr
- Ironport-phdr: 9a23:nYhR/RZpnFccp0cWLHCMEKb/LSx+4OfEezUN459isYplN5qZpsu9bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUD6PAtxDuH8Co/Xgsi60e2pvZPJMCtSgz/oWqJ2Mhy3qzL7sdQShAoqfp0gzgXAo30OUeNLwWZlDU+Vngi56d29+plp9ykVsvY5+tUGX7+sLPdwdqBREDlzazN938bsrxSWFQY=
Hello,
Thanks a lot Maxime, this solves the issue.
Sylvain.
-------- Message transféré --------
Date : Thu, 26 Oct 2017 18:34:18 +0200
De : Maxime Dénès
<mail AT maximedenes.fr>
Hello,
You need to add an 'open Ltac_plugin' in the files that depend on Ltac
(typically the ones containing TACTIC EXTEND macros, for example).
Hope it helps.
Maxime.
On 10/26/2017 06:17 PM, Sylvain Boulmé wrote:
Hello everybody,
I am trying to update the following plugin from v8.6 to v8.7:
https://github.com/VERIMAG-Polyhedra/VplTactic
My updated .ml and .ml4 files compile.
The Coq files do not seem to require an update.
But, on the Coq compilation, the following line
Declare ML Module "vpl_plugin".
fails with the following message (whereas everything works find in v8.6):
Error:
while loading /home/sylvain/VplTactic/src/vpl_plugin.cmxs:
error loading shared library:
/home/sylvain/VplTactic/src/vpl_plugin.cmxs: undefined symbol:
camlTacinterp
Do you have an hint about this issue ?
I have no idea on how to solve this.
Thanks,
S.
- [Coq-Club] plugin load issue, Sylvain Boulmé, 10/26/2017
- Re: [Coq-Club] plugin load issue, Maxime Dénès, 10/26/2017
- Re: [Coq-Club] plugin load issue, Sylvain Boulmé, 10/27/2017
