- From: Kenneth Adam Miller <kennethadammiller AT gmail.com>
- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fibonacci in Coq?
- Date: Fri, 27 Oct 2017 13:09:41 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kennethadammiller AT gmail.com; spf=Pass smtp.mailfrom=kennethadammiller AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f43.google.com
- Ironport-phdr: 9a23:EhR8mxa+FDp77ST2ldZ4x2b/LSx+4OfEezUN459isYplN5qZpcyybnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76xXcoFx7+LQt4IPjuUs6X1pzvlrP6x5qGaAJRwTG5fLk6BxGrp02Fvc4PxIBmN6wZyx3To3IOdf4Alk1yIlfGvBv64Mqs/NZK/y1V89cg88pNS+2ufKk+S7FEDD0qOmUw5cnvuAPrQg6G539aWWITxEkbSzPZ5Q33C8+i+hDxsfBwjWzDZZX7
These properties are likely going to be very helpful! I was actually digging around for some listing of these so that I could leverage them even just as you sent that. The links are rather very different to me, I probably would not have found them.
On Fri, Oct 27, 2017 at 12:29 PM, Pierre Letouzey <pierre.letouzey AT inria.fr> wrote:
That's probably not what you're looking for, but I couldn't resist advertizing this:
https://hal.inria.fr/hal-01195587/document
https://www.irif.fr/~letouzey/hofstadter_g/
tl;dr: playing with the recursive function g(n)=if n=0 then 0 else n-g(g(n-1)) leads to
strange worlds filled with Fibonacci numbers and fractal trees.
Regards
Pierre L.
----- Mail original -----
> Cool thanks!
> I'm looking for analytic continuations of the continuous series as well as
> an alternative to starting at zero, and lastly some theoretic derivations
> of it's convergence point, with the work shown.
> On Fri, Oct 27, 2017 at 2:51 AM, Laurent Thery <Laurent.Thery AT inria.fr>
> wrote:
> > On 10/26/2017 09:44 PM, Kenneth Adam Miller wrote:
> > > Hello,
> > > Does anybody know of any theorems or number theoretic work done using
> > > fibonacci in Coq?
> > > Thanks in advance!
> > I don't know which results you have in mind. The mathcomp has only some
> > basic properties of the fib function
> > https://github.com/math-comp/math-comp/blob/master/mathcomp/attic/fib.v
> > Laurent
> > Ps: fib.v is not part of the standard mathcomp library
- [Coq-Club] Fibonacci in Coq?, Kenneth Adam Miller, 10/26/2017
- Re: [Coq-Club] Fibonacci in Coq?, Laurent Thery, 10/27/2017
- Re: [Coq-Club] Fibonacci in Coq?, Kenneth Adam Miller, 10/27/2017
- Re: [Coq-Club] Fibonacci in Coq?, Pierre Letouzey, 10/27/2017
