- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Declaring a new axiom through ML tactic
- Date: Mon, 6 Nov 2017 18:05:42 +0000
- Accept-language: ja-JP, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=os0220 AT hotmail.com; spf=Pass smtp.mailfrom=os0220 AT hotmail.com; spf=Pass smtp.helo=postmaster AT APC01-PU1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:8PiORxGUczxTFPTltdDk751GYnF86YWxBRYc798ds5kLTJ76ocWwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVT1/0MhMwLeDoEKbTid623qa84debNw5PnX+2Za54BBSwtwTY8McM19hMMKE0n+Mx6oOwM7BR3jsyfwq7nxHg486x+Nho9CEG6KFpzNJJTaivJ/dwdrdfFjlza20=
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hi!
I want to implement a Coq tactic which consults some
outer resources and declares a new axiom based on those.
This will be useful for proving natural language theorems.
I wrote an OCaml code for this but it does not work as expected.
I'd like to have your help to fix this.
Here's my first attempt (I use Coq v8.6):
theory.v:
Parameter is_foo : nat -> Prop.
Definition def1 : Prop := (forall x : nat, is_foo x).
test.ml4:
DECLARE PLUGIN "test"
let contrib_name = "test"
let find_constant contrib dir s =
Universes.constr_of_global @@ Coqlib.find_reference contrib dir s
let init_constant dir s = find_constant contrib_name dir s
let imp = lazy (init_constant ["theory"] "def1")
let test = Proofview.Goal.nf_enter { enter = begin fun gl ->
let sigma = Tacmach.New.project gl and env = Tacmach.New.pf_env gl in
let cexpr = Constrextern.extern_type true env sigma (Lazy.force imp) in
let loc_ident = (Loc.ghost, Names.Id.of_string "axiom1") in
let pl = (loc_ident, None) in
let l = [false, ([pl], cexpr)] in
let status = Command.do_assumptions (Decl_kinds.Global, false, Decl_kinds.Logical) Vernacexpr.NoInline l in
Tacticals.New.tclIDTAC (* put this to end with tactic type *)
end }
TACTIC EXTEND _test_
| [ "test" ] -> [ test ]
END
end }
END
This fails and leads to an anomaly:
$ coq_makefile test.ml4 -o Makefile; make; coqc theory.v
$ coqtop
Welcome to Coq 8.6 (November 2017)
Coq < Declare ML Module "test".
[Loading ML file test.cmxs ... done]
Coq < Require Export theory.
Coq < Goal forall x, is_foo x.
1 subgoal
1 subgoal
Unnamed_thm < test.
axiom1 is declared
1 subgoal
Unnamed_thm < apply axiom1.
No more subgoals.
Unnamed_thm < Qed.
test.
(apply axiom1).
Qed.
Toplevel input, characters 0-4:
> Qed.
Anomaly: Uncaught exception Not_found. Please report at
http://coq.inria.fr/bugs/.
axiom1 is declared
1 subgoal
No more subgoals.
Unnamed_thm < Qed.
test.
(apply axiom1).
Qed.
> Qed.
However, this new axiom is available for proving other theorems
after exiting from the proof with Admitted.
Unnamed_thm < Admitted.
Unnamed_thm is declared
1 subgoal
Unnamed_thm0 < apply axiom1.
No more subgoals.
Unnamed_thm0 < Qed.
(apply axiom1).
Qed.
Unnamed_thm0 is defined
I suspect the problem relates to Environ.env.
The defined axiom resides on Global.env but not seeable from
the proof session for Unnamed_thm somehow...
Thanks,
Masashi Yoshikawa
- [Coq-Club] Declaring a new axiom through ML tactic, 吉川 将司, 11/06/2017
